Lee when you fit it do you remove the ODB socket from the panel so the whole lot is behid it or does it stick out?
cant see it really, its not intruseve
I was keen on this item but was told at night it reflects on the drivers side mirror making the view impeded.
good bit of kit.
Looks very smart. Tempted to get this but rather expensive.
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
Imperial or Metric units can be set independently for the different gauge and graph types.
Extended graph and gauge scaling from 200bhp/ftlb to 500bhp/ftlb.
Second multi gauge display added (Air, Coolant, N75, Boost).
Speed and RPM display added.
Auto power off function added to most displays on engine off.
Auto power off function in main displays after 1 minute of non use.
Auto return to last gauge displayed on turn on.
Diesel 1.9Tdi engine support added for cars other than the TT.
Selectable BHP/Torque calculation method between ECU MAF and Torque data.
Use a standard yellow bit in the hole, and screw into that![]()
Yea we fit these at awesome.....
Hello there.
Do you make a housing for these to go into the right-hand vent in the CENTRE of the dash, as opposed to the drivers side "door" vent?
Thanks in advance mate
By the way looks good & well done LEE69![]()
