Throttle Body gasket part No
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
I'm changing my inlet manifold soon and need a new gasket for my TB. I have this part number for the LCR one 028129748
Is it the same gasket for the LC?
Its AUQ engine with DBW throttle.
If someone knows or has some way of finding out would really appriciate it :)
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Don't surpose you know the part no for the injector seals that go in the AUQ inlet manifold?
The black ones as the ports bolt to head.
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
These are the bits, think there actually called seats not seals, same as that but fot LC AUQ
csd_19
2,280
28
Angus / Edinburgh
From what I can see, yep :)
Only one I'm not 100% confident about is the injector seats - there seems to have been at least 3 different versions fitted to the 1.8T, still looking into these. The TB gasket and injector o-rings are a deffo though.
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Thanks very much, do you know if there are 4 or 8 inector seals?
I don't actually think my injectors leak but if there only cheap I'll replace them anyway.
csd_19
2,280
28
Angus / Edinburgh
8 seals altogether, top and bottom of each injector where it attaches to the fuel rail and where it sits in the seat :)
Can you see staining around the injector seats?
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Cheers :)
Yeah I can but I'm not sure if its petrol or if someone has split some oil......I'm thinking its petrol.
I take it the 8 seals are the same?
I reckon garage may sting me for these, might be better off just getting some o rings from motor factors if they would do?
csd_19
2,280
28
Angus / Edinburgh
If the staining is around all 4 seats then it sounds like fuel to me unfortunately! Mine are the same.
The 8 seals are the same top and bottom on the LC, different on the LCR iirc. Can't tell you the size unfortunately! not sure how much the stealers would ask for them, could be worth pm'ing Serle Motors to see?
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Yeah its all 4 on mine.
I got a TPS card so I'll get them from there, think there £2 odd each so £16 ish, just seems a lot for 8 o rings as I bought a box of 100 for £2 to use with my fishing stuff.
I think I'm just being tight to be honest :cartman:
Thanks ever so much for all your help, really appriciate it :):)
