bubba
190
like an idiot ive broken the badge on the boot of my ibiza the badge that opens the boot not the handle just the badge. is there a way to get this off? ive tryd searching but cant find anything
i think you have to replace the whole unit iirc sorry , in interest how? . the lock mech is held in with three nuts under the bootlid cover fairly easy to remove though
ive stripped the whole thing down in the past you can buy a new unit from seat but its £££ as contains a lock and all, if you remove the s lock item you can use a punch to remove the shaft the holds the S badge heres the pin
tap it through pull it out hey presto just be warned if i can remember it has springs on it so be careful when removing it
i managed to break the badge as i noticed a crack i pulled it and lo and behold it snappd. if i mange to get it off can i buy the badge on its own?
is it easy to get thepin back in?
Yeah the pin comes out and goes back ok, just grease it up when you put it back in, i would have thought you should be able to buy it seperate yeah, if not scrappies as suggested.
thanks for your help all ive found the the handle and badge for sale off a leon cupra. do you think this will fit the ibiza im geussing they are the same?
