dannychapman10
K04 Time ;)
Mar 30, 2009
1,268
Grimsby, UK
Thanks matey :) Still need to swap the adapter for one that allows MFSW and need arial adapter but I only use USB with my tiiiiny 8GB usb stick and i hae a remote so im good for now.
Wasnt easy mate haha, surface mounted LEDS intracate stuff, thats after identifying and carefully removing the original ones, a bit of electronics savy, a multi meter and a steady hand....
Like I say ^ ;) The main bit of the job is soldering. I had a guide (in spanish :confused: ) that helped Ill try and dig it out. Removal of the panel is easy enough
Yeah, I got quoted about £50-60 for the steering wheel adaptor and I just bought the aerial adaptor, £15 I think from my local audio shop. If you have a stubby aerial on the car you may find reception isn't as good now :(
Danny.
Tfsi_Mike
2,387
Doncaster / Germany (Army)
Danny.
I bought an arial adapted, it was amplified and seemed ok but thought I never use the radio so exchanged it for a tool i needed. I have the short citron ariel like
robdf2
Yellow is the best
Feb 21, 2006
3,605
location , location
Mike who is the boost gauge holder coming from to hold the new south gauge?
is it for the 52mm version? and do you know how much it will cost?
i already have a new south gauge and have made a holder but would like to see pics of the bespoke made one to see how it looks.
Blade
1,386
32
Thanks mate ;)
Fitted soon....
Would be very interested to know your thoughts on the WALK kit. Hopefully it will help eliminate the dreaded wheel hop scenario
Tfsi_Mike
2,387
Been told a holder has just been produced / released (see awesome gti 12 days of xmas thread) Lookin forward to seeing it myselfi Also had a holder made uo but would prefer somethin more oem...
Tfsi_Mike
2,387
Thanks mate ;)
Fitted soon....
Probably have it fitted In Jan now... will let you know.
20k Service and xmas to get out of the way first :(
In Jan comes the diff, the other 2 VWR mounts, WALK fitted, grooved discs with ferreddo pads and maybe try the new ITG filter :D
Al
7,326
9
Which diff, where you getting it fitted and approx cost lad? Its something I really something I should have too.
Tfsi_Mike
2,387
Al
7,326
9
Willie has been looking at the wavetrack diffs. Supposed to be a step on from the likes of Quaiffe and Peolquin.
Tfsi_Mike
2,387
Any one with stage 2+
What is the likely hood of wheel spin dropping 6th to 5th and puttin the power down or 5th to 4th and powering down?
On hard acceleration occasionally getting a judder and now and again slight rise in revs
Had the Sachs clutch plate fitted with my existing pressure plate and a new dal mnass flywheel. Cant afford to be damaging or prematurely wearing the new bits!!! :(
Is the judder likely to be wheelspin, or cutch slip???
Poverty
In the dry mine doesnt spin in 5th. I presume you have esp off?
What grooved discs are you looking at?
I hate xmas, means no mods for the car :(
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Sounds more like clutch slip. Unless you have poor tyres / low tread / ice / heavy standing water (but then if you had inclement weather you wouldn't go WOT :rolleyes:)
Tfsi_Mike
2,387
Goodyear assymetrics slightly worn on inside addmitedly and towards en of thier life.
No ice or standing water, possibly damp or greasy occasionally.
Concerned its going to wear quickly :cry:
Poverty
what is your clutch rated at?
Al
7,326
9
My standard clutch never does anything untoward and i never have revs do anything they shouldnt, like what you mentioned above. I have been in a mapped MK2 Leon Cupra with no other mods that did though, again on standard clutch.
