lcr rear de wiper
harty190486
POWER!!!
Dec 29, 2008
349
staffordshire
harty190486
POWER!!!
Dec 29, 2008
349
staffordshire
Probably from B+Q or even an electrical wholesalers make sure its a 25mm blind grommet im a spark so ave them lying around in the van , good luck mate really simple to do
Nef
Looking Rather Dappa
Mar 30, 2009
626
Cambridge
halfords do them mate, about £1.56 for a 24mm one i think then they do a pack of 3 21, 22, 23mm also for £1.56.
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
As you look at the washer bottle off on the left its the right hand tube down the side of the charcole filter follow the right hand tube from the pump just pull it off its only a few inches from the pump
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
thanks guys.
If i just remove the pipe from the bottle i take it the bottle wont leak? Or do i need to block it off with something?
Also, is there a fuse for the rear washer pump?
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
Not sure where to hide the jets as don't want them on show as I have no grill but will think of some thing . Can't hurt as washer fluid is the same as methonol but with detergant in . Obv watered down a tad
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Mine are mounted under cooler like this
Once one the bracket goes under bumper and you can't really see the jets, you'd never notice they were there unless you were looking for them.
