Probably from B+Q or even an electrical wholesalers make sure its a 25mm blind grommet im a spark so ave them lying around in the van , good luck mate really simple to do
halfords do them mate, about £1.56 for a 24mm one i think then they do a pack of 3 21, 22, 23mm also for £1.56.
As you look at the washer bottle off on the left its the right hand tube down the side of the charcole filter follow the right hand tube from the pump just pull it off its only a few inches from the pump
thanks guys.
If i just remove the pipe from the bottle i take it the bottle wont leak? Or do i need to block it off with something?
Also, is there a fuse for the rear washer pump?
Not sure where to hide the jets as don't want them on show as I have no grill but will think of some thing . Can't hurt as washer fluid is the same as methonol but with detergant in . Obv watered down a tad
Mine are mounted under cooler like this
Once one the bracket goes under bumper and you can't really see the jets, you'd never notice they were there unless you were looking for them.
