For Shaun!
my boot install - sub under the floor inside the spare wheel; box contains battery and amp.
Bay shots:
the negative terminal is just taped up held out of the way.. car will be going standard before I sell up :)
down at the starter motor - use the positive terminal for you wire to the boot and the wire to the fuse box.. yea, ii'm not too fussed about it being pretty, it works though :D
btw, spaghetti junction is because I have HID dipped beam and 130watt main beam on a separate loom with relays inside the headlights.. there is also wires going to my oil temp pick up and radar detector head.!
I'm waiting to see your roof before I think about getting mine done, but mine will only be vinyl..
but it is fun nicking roadcones and you get really odd looks from passers by!!
