I belive you can swap the floats over.
I didnt bother i just made sure the arrows where lined up im pretty sure it reads very slightly lower but not enough to worry me.
This is a TT225 pump in my MK3 Ibiza. Fuel level is correct.
Left hand side of the pic is the drivers side, right is passengers.
For ref part number is 8L9 919 051 J
http://www.seatcupra.net/forums/showpost.php?p=2455609&postcount=116
When I last filled up until it clicked on the pump (~£45) my fuel gauge read between 3/4 and full
nice one guys il try and allign it 2 moro and fit my window reg too yay! lol havent had any electric windows for close to 2 weeks
hmmm from the two pics both seem to be in different places so is that where your arrow is on the car jive jester??
I think the fact it's a slightly different pump may be deceptive. If you refer to my other pic from the above post in my project thread you can see that both mine and JiveJester's are lined up the same:
ye i think your right robbie i got the pierberg lcr one form euro car parts and i think it is slightly different to both lol
Where's the best place to get these pumps?
Anyone know if there okay to use with Revo Stage 2 and a k03's?
eurocarparts, yes and yes with good results higher up the rev range i found
Ah right cheers for the quick reply.
So worth getting then? and ok to run with the 4bar regy?
Would adjusting the fueling make much of a difference or is it not really worth it?
id recommend it if ur fuel pump has done good mileage as mine was running lean on last rr with revo stage 2 ko3s etc
Yeah my car has done a few miles. I not a sure if the pump is original or not. But this could be a good upgrade
