As said before, it is a replacement unit, but i have paperwork from a seat dealer that a new clock set was installed and was recoded
There is no reason why it won't work, unless bending the pins before as now damaged the clocks possibly?
no, i mean that today you have removed the clocks from your car and replaced them with a different set. its irrellavent that they have been replaced in the past. as long as you put the same clocks back in that you took out then no issues should have arose.
have you checked the pins?
I'm really puzzled as to why you're unable to lock or unlock the car doors manually. This has nothing at all to do with the immobiliser or remote central locking. I agree that if things are screwy that you won't be able to start the car or unlock the doors with the remote, but if you can't put a key in the lock, turn it, and the car unlocks then you've got a real problem.![]()
I'm really puzzled as to why you're unable to lock or unlock the car doors manually. :
you will need to recode the immo to keys it is a rolling code unplug for more than 10 mins xxxx ok
I know on my audi when i did my reset I disconnected both terminals and joined them together for 30 mins and it worked. Had probs with starting, central locking and immbo and it cured it.
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
All i did was take out the clocks to see if i could change the bulbs. Thought it was too much hassle
