id recommend it if ur fuel pump has done good mileage as mine was running lean on last rr with revo stage 2 ko3s etc
Have you got before and after RR results to compare any gains?
I want to get an uprated fuel pump on mine
. then guna get coil packs and plugs You have to take the unit off the Ibiza pump. I couldn't be bothered so I just threw it in with the LCR sender unit on!
I will have to take it back out soon though so I'm regretting the decision already!
Easy job to swap them over?
Where is the fuel pump actually located? Is it underneath the rear seats or around that area?
My fuel guage does not go up that high when i put fuel in, but the trip computer seems to give the correct reading, also the fuel needle does drop very slowly
