Engine block corner gone - only two bolts left - options!
Mewcenary
156
Farnham, Surrey
Rev-linked engine bay WHINING, goes away on the throttle, comes back off the throttle
Hi,
I have a 2002 Seat Leon with 120k on the clock. Things generally fine until last night when I do a bit of reversing, then switch back to forward gears.
Since then there is a high-pitched WHINE which is linked to revs. It is present from ignition but goes away when the throttle is engaged (in gear). As soon as I come off the throttle it comes back.
No change in driving performance that I can spot... It's just the noise.
If I accelerate more quickly there is a CLUNK (seemingly from driver side engine bay/front wheel) before it goes away. Obviously, I've started driving more smoothly so that isn't happening now.
Local garage suspect cambelt tensioner but aren't free to work on it so it looks like an official stealers job. Before I take it in, what else could it be???
Mewcenary
156
Farnham, Surrey
Closer look shows it is belt-related.
Engine bolt has broken so the engine has shifted in position. This has forced the belt cover off. Also, the belt started eating through an adjacent bit of metal! Hence lots of noise and scouring on the belt.
Fix = new belt + put engine back in position and rectify bolt situation, according to stealers...
Mewcenary
156
Farnham, Surrey
Hi,
Seat Leon Cupra 2002 with 120k miles.
A failure of one bolt holding the engine block in place has caused a corner of the engine block to shear off (taking the bolt fixings etc with it).
This leaves me with two 'good' bolts (according to stealer).
What are my options?
1. Secure engine with just two bolts (!)
2. Replace engine block (stealer quote - £1500 !)
3. Something else ???
Advise please guys...
As an aside, the change in angle of the engine meant the belt cover came off and was rubbing against the belt. Visible scouring. Also replace?
Thanks,
Tris.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
If you can imagine the forces that caused part of the block to break away, you wouldn't want to be running on less than the full complement of fixings. :scary:
Replace block - although sourcing a second hand complete engine and fitting would probably work out cheaper.
Mewcenary
156
Farnham, Surrey
Do 'quick fix', then P/X for another car. The only reason I haven't switched to a diesel recently is not wanting the initial outlay, but now that my hand is being forced, things are different :(
I do about 20k a year easy so the Cupra is not the most efficient.
Still feel sad though.
lc_allan
Northern Monkey
Sep 15, 2006
3,389
Can anyone not fabricate a kind of plate to use your existing chassis mounting point but still support the block?. At least get it back up level to reduce the strain on the other bolts.
Even if that's temporary until P/X sold etc.. I have no idea about engine blocks or mounting points but I'm sure someone could bodge it :)
Mewcenary
156
Farnham, Surrey
Well, the guy is looking into that option for me over the weekend via some engineering contacts. No idea if it is viable. However, when you start doing that sort of thing you instantly remove your P/X option due to big wodges of metal being stuck on the engine ;)
Oh, my £1500 quote was wrong. They have quoted that for the engine block ALONE. So add on labour and all the other gubbins on top of that. Just not worthwhile for current value of car in the slightest.
Mewcenary
156
Farnham, Surrey
Any thoughts on feasibility of welding / other form of block repair? Or just not possible?
Also, does it sound right that there are three mounting points for the engine in the first place?
xr2turbo
175
norfolk
without a pic its diff but you could make a plate from the existing holes to take up the difference in angle but you need to take another fixing really
what not 'out it' spare repairs, i'd have a deal :lol:
i cant imagine 2 bolts leave it on the piss, i had an escort turbo with a zvh lump in knocking well over 200 nags, i didnt mod the mount i just cut the 3rd bit out (2 line up but the bottom area fouls the oil pump on a zetec big end) so it cleared the oil pump, it never had an issue (daft considering i actually fab zvh mod mounts and sell em :lol:)
Mewcenary
156
Farnham, Surrey
Thanks for the link. I'll speak to the dealer on Monday. They should be able to clarify whether it is just the mounting ear that has come off or something more substantial...
Mewcenary
156
Farnham, Surrey
DPJ: LC charge pipe bracket?
m0rk: I do, but the car is at the stealers so I'm not in the position to look. I've sent them the details and will phone them Monday morning so they can confirm it is 'just' the ear which has broken so the fix is appropriate.
Found this in relation to the 'ear' fix:
http://forums.tdiclub.com/showthread.php?t=246428
The original post matches my situation EXACTLY, other than it being the fact I shifted from reverse to first as the final shock to the chassis which caused the failure. Right down to the whining as the belt starts cutting through the aluminium!
Mewcenary
156
Farnham, Surrey
The one bit I don't 'get' is that they only make the kit for the passenger side rear mount? Is the other side a different type of attachment so it won't break in the same fashion...?
