cruise control not working???
ashley600
193
leicester
help cruise control decided not to play today, had a quick search and have checked the brake light switch which is fine.
any ideas anyone??
Viking
Insurance co's are crap.
May 19, 2007
2,317
Near Richmond, North Yorks
How do you know your brake switch is fine? It has 2 channels, one for the lights and one for the ecu to monitor so that the cruise can be deactivated when you brake. the lights may be coming on but the switch might still be goosed. VCDS scan would confirm the fault more effectively.
CupraMVR
Awesome GTi Technician
Oct 19, 2006
1,371
Crewe Cheshire
Need vag com engine group and measuring blocks group. 060
this will tell you if the cruise is working and if the brake and clutch pedal switches are working aswell
vee_dub_modder
Volkswagen racing tech-pt
Feb 19, 2008
406
Midlands
usually brake or clutch pedal switch, sometimes the stalk but rarely -- can also be checked with a multi meter -- on/off on both switches. if your brake lights come on then you know thats working so most likely clutch switch.
ashley600
193
leicester
Cheers now I know what I'm looking just need to get it scanned.
Still need to sort that shifter out with you john now Xmas is done with
mikeholroyd
This is an issue that is frequently discussed on Briskoda, with many Octavia owners having the same problem. It can quite often be nothing more than dirty contacts in the switch. And after all, it's basically the same car, with exactly the same components fitted.
There is a procedure to take the switch apart and clean the contacts, I did the translation myself from the original Danish version. Check out post 14 of this link
http://briskoda.net/forums/topic/12...-i-change-it-myself/page__hl__cruise cleaning
Dead easy to do, took me less than half an hour from start to finish.
Hope this helps
Mike
ashley600
193
leicester
Hope this helps
Mike
Right followed the guide and managed to get the stalk open and access the workings, all looks factory fresh in there plenty of glease and no sign of any crude so looks like it's a switch.
Vag com help needed
mikeholroyd
Vag com help needed
Have you taken the switch completely apart?
The cruise switch on my Octavia looked factory fresh as well, but you couldn't see the dirt on the contacts themselves until it was dismantled. Even though it might look like it has plenty of grease in there, clean it off and give the guide a go -- it got my cruise working again,and it has never given any problems since. Plenty of grease means plenty of area for dust to stick to.
End of the day, it's not going to cost you anything to give it a good clean, but it will cost you if you start changing switches etc.
Good luck
Mike
