stock map returned, not faulty code but car not run fine
same boost deviation code?
post logs of block 115
stock boost is unlikely to trip +ve deviation
checked your pipes?
you said you adjusted actuator... which way? and why?
mine was mapped and wastegate was adjusted.adjusted it back to fine out that the map was poor so now i have revo stage 2 and works really good:D
I do not know English well, I hope you understand me correctly. when the car is in original file did not go well. When load a custom file all is OK but for a specified time 100-150km and then again 17963. I think ecu is broken.
If someone wants to send his file which drive to see if it is done correctly.
files aint free here sir
deviation code is probably a deviation... do you have any vagcom logs you can post up of block 115?
I will send a file. I did not write correctly. Tomorow post result from block 115
Friday,08,January,2010,13:58:37
6K0 906 032 AA,,1.8L 20VT EU3 0002,
,Group A:,'115,,,,Group B:, Not Running,,,,Group C:, Not Running
,,RPM,Load,Absolute Pres.,Absolute Pres.,,,,,,,,,,
,TIME,,,,,TIME,,,,,TIME,,,,
Marker,STAMP, /min, %, mbar, mbar,STAMP,,,,,STAMP,,,,
,0.00,1400,33.1, 1010.0,1030.0,,,,,,,,,,
,0.30,1480,33.8, 1010.0,1030.0,,,,,,,,,,
,0.60,1600,34.6, 1010.0,1030.0,,,,,,,,,,
,0.90,1680,37.6, 1010.0,1030.0,,,,,,,,,,
,1.20,1840,47.4, 1010.0,1030.0,,,,,,,,,,
,1.50,2120,74.4, 1180.0,1030.0,,,,,,,,,,
,1.80,2480,85.7, 1160.0,1160.0,,,,,,,,,,
,2.10,2920,94.0, 1460.0,1320.0,,,,,,,,,,
,2.40,3480,133.1, 1920.0,1540.0,,,,,,,,,,
,2.71,4440,136.1, 1910.0,1690.0,,,,,,,,,,
,3.01,5280,148.1, 1870.0,1760.0,,,,,,,,,,
,3.31,5760,139.8, 1860.0,1750.0,,,,,,,,,,
,3.61,6040,136.1, 1800.0,1660.0,,,,,,,,,,
,3.91,6400,103.0, 1010.0,1530.0,,,,,,,,,,
,4.21,5640,10.5, 1010.0,1320.0,,,,,,,,,,
,4.51,4280,85.7, 1980.0,1040.0,,,,,,,,,,
,4.81,4120,132.3, 2000.0,1610.0,,,,,,,,,,
,5.11,4400,138.3, 1980.0,1660.0,,,,,,,,,,
,5.41,4680,156.4, 1950.0,1890.0,,,,,,,,,,
,5.71,4960,154.9, 1920.0,1860.0,,,,,,,,,,
,6.01,5240,151.9, 1910.0,1840.0,,,,,,,,,,
,6.31,5480,147.4, 1910.0,1840.0,,,,,,,,,,
,6.61,5720,145.1, 1910.0,1800.0,,,,,,,,,,
,6.91,5920,141.4, 1860.0,1770.0,,,,,,,,,,
,7.21,6160,136.8, 1810.0,1730.0,,,,,,,,,,
,7.51,5960,18.0, 1010.0,1660.0,,,,,,,,,,
,7.81,5360,8.3, 1010.0,1190.0,,,,,,,,,,
,8.10,4160,103.8, 1990.0,1130.0,,,,,,,,,,
,8.41,4320,128.6, 1970.0,1700.0,,,,,,,,,,
,8.71,4440,145.1, 1960.0,1720.0,,,,,,,,,,
,9.00,4600,153.4, 1950.0,1920.0,,,,,,,,,,
,9.31,4680,155.6, 1940.0,1890.0,,,,,,,,,,
,9.61,4840,157.1, 1930.0,1920.0,,,,,,,,,,
,9.91,4960,156.4, 1910.0,1910.0,,,,,,,,,,
,10.21,5080,154.9, 1900.0,1890.0,,,,,,,,,,
,10.51,5160,152.6, 1900.0,1860.0,,,,,,,,,,
,10.81,5280,150.4, 1910.0,1860.0,,,,,,,,,,
,11.11,5400,149.6, 1910.0,1860.0,,,,,,,,,,
,11.41,5480,148.1, 1920.0,1880.0,,,,,,,,,,
,11.71,5560,147.4, 1920.0,1870.0,,,,,,,,,,
,12.01,5680,147.4, 1930.0,1870.0,,,,,,,,,,
,12.31,5760,146.6, 1920.0,1850.0,,,,,,,,,,
,12.61,5840,144.4, 1900.0,1850.0,,,,,,,,,,
,12.91,5920,142.1, 1300.0,1840.0,,,,,,,,,,
,13.21,5760,16.5, 1010.0,1470.0,,,,,,,,,,
,13.51,4880,64.7, 1830.0,1070.0,,,,,,,,,,
,13.80,4680,133.1, 1850.0,1560.0,,,,,,,,,,
,14.11,4720,131.6, 1850.0,1610.0,,,,,,,,,,
,14.41,4800,148.1, 1840.0,1800.0,,,,,,,,,,
,14.70,4840,146.6, 1840.0,1810.0,,,,,,,,,,
,15.00,4880,151.1, 1830.0,1830.0,,,,,,,,,,
,15.30,4960,152.6, 1830.0,1850.0,,,,,,,,,,
,15.60,5040,149.6, 1830.0,1840.0,,,,,,,,,,
,15.90,5080,149.6, 1830.0,1820.0,,,,,,,,,,
,16.20,5120,148.9, 1830.0,1820.0,,,,,,,,,,
,16.50,5160,148.1, 1840.0,1810.0,,,,,,,,,,
,16.80,5240,148.1, 1840.0,1810.0,,,,,,,,,,
,17.10,5280,146.6, 1840.0,1820.0,,,,,,,,,,
,17.40,5320,147.4, 1840.0,1830.0,,,,,,,,,,
,17.70,5360,147.4, 1840.0,1810.0,,,,,,,,,,
,18.00,5400,145.1, 1840.0,1830.0,,,,,,,,,,
,18.30,5480,145.9, 1840.0,1810.0,,,,,,,,,,
,18.60,5520,145.1, 1850.0,1820.0,,,,,,,,,,
,18.90,5480,25.6, 1010.0,1760.0,,,,,,,,,,
,19.20,4960,9.8, 1010.0,1220.0,,,,,,,,,,
,19.50,4480,110.5, 1890.0,1220.0,,,,,,,,,,
,19.80,4480,128.6, 1890.0,1730.0,,,,,,,,,,
,20.10,4520,143.6, 1880.0,1700.0,,,,,,,,,,
,20.40,4560,149.6, 1880.0,1910.0,,,,,,,,,,
,20.70,4600,151.9, 1870.0,1880.0,,,,,,,,,,
,20.99,4600,156.4, 1870.0,1920.0,,,,,,,,,,
,21.30,4640,155.6, 1800.0,1930.0,,,,,,,,,,
,21.60,4760,30.1, 1010.0,1520.0,,,,,,,,,,
,21.90,4600,9.8, 1010.0,1190.0,,,,,,,,,,
,22.20,4560,6.8, 1010.0,1120.0,,,,,,,,,,
,22.50,4560,8.3, 1010.0,1080.0,,,,,,,,,,
,22.79,4520,8.3, 1010.0,1070.0,,,,,,,,,,
,48.28,1520,54.9, 1010.0,1050.0,,,,,,,,,,
,48.58,1640,78.9, 1450.0,1080.0,,,,,,,,,,
,48.88,1800,89.5, 1560.0,1160.0,,,,,,,,,,
,49.18,1960,97.7, 1640.0,1270.0,,,,,,,,,,
,49.48,2160,111.3, 1920.0,1410.0,,,,,,,,,,
,49.78,2400,128.6, 1930.0,1600.0,,,,,,,,,,
,50.08,2640,145.1, 1920.0,1830.0,,,,,,,,,,
,50.38,2960,153.4, 1920.0,1940.0,,,,,,,,,,
,50.69,3280,157.1, 1900.0,1960.0,,,,,,,,,,
,50.98,3560,151.9, 1890.0,1920.0,,,,,,,,,,
,51.29,3840,149.6, 1900.0,1840.0,,,,,,,,,,
,51.59,4160,151.9, 1900.0,1870.0,,,,,,,,,,
,51.89,4440,152.6, 1870.0,1850.0,,,,,,,,,,
,52.19,4720,151.9, 1850.0,1810.0,,,,,,,,,,
,52.49,5000,151.1, 1830.0,1790.0,,,,,,,,,,
,52.79,5240,147.4, 1830.0,1790.0,,,,,,,,,,
,53.09,5480,143.6, 1840.0,1770.0,,,,,,,,,,
,53.39,5720,112.8, 1010.0,1640.0,,,,,,,,,,
,53.69,5200,10.5, 1010.0,1310.0,,,,,,,,,,
,53.99,4320,29.3, 1870.0,1100.0,,,,,,,,,,
,54.28,3880,120.3, 2010.0,1380.0,,,,,,,,,,
,54.59,4000,127.1, 2000.0,1640.0,,,,,,,,,,
,54.89,4120,149.6, 1990.0,1840.0,,,,,,,,,,
,55.19,4240,152.6, 1970.0,1940.0,,,,,,,,,,
,55.49,4400,159.4, 1960.0,1970.0,,,,,,,,,,
,55.79,4520,160.2, 1950.0,1980.0,,,,,,,,,,
,56.09,4640,160.2, 1940.0,1950.0,,,,,,,,,,
,56.39,4760,157.9, 1910.0,1930.0,,,,,,,,,,
,56.69,4880,155.6, 1900.0,1890.0,,,,,,,,,,
,56.98,4960,154.9, 1900.0,1870.0,,,,,,,,,,
,57.28,5080,153.4, 1890.0,1860.0,,,,,,,,,,
,57.58,5200,151.9, 1900.0,1840.0,,,,,,,,,,
,57.88,5280,148.9, 1900.0,1840.0,,,,,,,,,,
,58.18,5400,148.1, 1910.0,1850.0,,,,,,,,,,
,58.48,5480,148.9, 1910.0,1850.0,,,,,,,,,,
,58.78,5560,146.6, 1910.0,1860.0,,,,,,,,,,
,59.08,5680,124.1, 1010.0,1810.0,,,,,,,,,,
,59.38,5240,12.8, 1010.0,1360.0,,,,,,,,,,
,59.68,4400,90.2, 1860.0,1060.0,,,,,,,,,,
,59.98,4480,133.1, 1860.0,1700.0,,,,,,,,,,
,60.28,4520,131.6, 1860.0,1580.0,,,,,,,,,,
,60.58,4560,146.6, 1860.0,1840.0,,,,,,,,,,
,60.88,4600,144.4, 1850.0,1750.0,,,,,,,,,,
,61.18,4680,150.4, 1850.0,1870.0,,,,,,,,,,
,61.48,4720,151.1, 1840.0,1860.0,,,,,,,,,,
,61.78,4760,150.4, 1840.0,1850.0,,,,,,,,,,
,62.08,4840,151.1, 1820.0,1830.0,,,,,,,,,,
,62.38,4880,149.6, 1820.0,1840.0,,,,,,,,,,
,62.68,4920,148.9, 1810.0,1810.0,,,,,,,,,,
,62.98,5000,148.1, 1820.0,1810.0,,,,,,,,,,
,63.28,5040,147.4, 1820.0,1820.0,,,,,,,,,,
,63.58,5080,148.1, 1820.0,1810.0,,,,,,,,,,
,63.88,5120,148.9, 1820.0,1800.0,,,,,,,,,,
,64.18,5160,146.6, 1820.0,1810.0,,,,,,,,,,
,64.48,5200,145.9, 1830.0,1820.0,,,,,,,,,,
,64.78,5240,146.6, 1830.0,1800.0,,,,,,,,,,
,65.08,5280,144.4, 1840.0,1810.0,,,,,,,,,,
,65.38,5320,145.9, 1840.0,1820.0,,,,,,,,,,
,106.45,2320,47.4, 1010.0,1080.0,,,,,,,,,,
,106.75,2400,46.6, 1010.0,1090.0,,,,,,,,,,
,107.05,2480,59.4, 1010.0,1080.0,,,,,,,,,,
,107.35,2600,86.5, 1550.0,1140.0,,,,,,,,,,
,107.65,2760,115.8,1930.0,1400.0,,,,,,,,,,
,107.95,3040,133.1,1920.0,1700.0,,,,,,,,,,
,108.25,3320,152.6,1900.0,1820.0,,,,,,,,,,
,108.55,3640,148.9,1900.0,1870.0,,,,,,,,,,
,108.86,3960,154.9,1910.0,1900.0,,,,,,,,,,
,109.16,4200,154.9,1890.0,1910.0,,,,,,,,,,
,109.46,4560,157.1,1880.0,1860.0,,,,,,,,,,
,109.76,4760,154.9,1860.0,1840.0,,,,,,,,,,
,110.06,5040,153.4,1840.0,1810.0,,,,,,,,,,
,110.36,5280,148.1,1850.0,1800.0,,,,,,,,,,
,110.66,5560,142.9,1860.0,1780.0,,,,,,,,,,
,110.96,5760,142.9,1840.0,1760.0,,,,,,,,,,
,111.26,6000,124.8,1010.0,1750.0,,,,,,,,,,
,111.56,5480,12.0, 1010.0,1360.0,,,,,,,,,,
,111.86,4680,21.8, 1840.0,1120.0,,,,,,,,,,
,112.15,4120,123.3,2000.0,1410.0,,,,,,,,,,
,112.45,4200,127.8,1980.0,1670.0,,,,,,,,,,
,112.75,4360,154.1,1970.0,1830.0,,,,,,,,,,
,113.06,4480,150.4,1950.0,1870.0,,,,,,,,,,
,113.36,4600,157.9,1940.0,1900.0,,,,,,,,,,
,113.66,4720,158.6,1930.0,1930.0,,,,,,,,,,
,113.96,4840,157.9,1900.0,1910.0,,,,,,,,,,
,114.26,4960,155.6,1890.0,1880.0,,,,,,,,,,
,114.56,5080,154.1,1890.0,1850.0,,,,,,,,,,
,114.86,5200,151.1,1890.0,1850.0,,,,,,,,,,
,115.16,5280,149.6,1900.0,1830.0,,,,,,,,,,
,115.46,5400,148.1,1900.0,1850.0,,,,,,,,,,
,115.76,5480,148.9,1910.0,1850.0,,,,,,,,,,
,116.06,5600,145.9,1920.0,1850.0,,,,,,,,,,
,116.36,5680,145.1,1910.0,1850.0,,,,,,,,,,
,116.66,5800,145.1,1900.0,1860.0,,,,,,,,,,
,116.96,5880,145.1,1890.0,1840.0,,,,,,,,,,
,117.26,5960,142.1,1880.0,1840.0,,,,,,,,,,
,117.56,6040,141.4,1200.0,1840.0,,,,,,,,,,
,117.86,5840,15.0, 1010.0,1460.0,,,,,,,,,,
,118.16,4920,90.2, 1820.0,1060.0,,,,,,,,,,
,118.46,4800,130.8,1830.0,1670.0,,,,,,,,,,
,118.76,4840,136.1,1830.0,1620.0,,,,,,,,,,
,119.06,4880,146.6,1830.0,1810.0,,,,,,,,,,
,119.36,4960,149.6,1820.0,1810.0,,,,,,,,,,
,119.66,5000,151.1,1820.0,1840.0,,,,,,,,,,
,119.95,5080,143.6,1540.0,1840.0,,,,,,,,,,
,120.25,5000,24.8,1010.0,1420.0,,,,,,,,,,
,120.54,5000,8.3,1010.0,1180.0,,,,,,,,,,
,120.84,4960,7.5,1010.0,1110.0,,,,,,,,,,
,121.15,4920,9.0,1010.0,1090.0,,,,,,,,,,
during this run it popped a +ve deviation boost fault code yea?
Code:
There's a 1bar boost request in here and 0.3bar actual
this your perfomance code or your standard? (its in between on boost levels)
when i reflashed with any new file from my big colection from all tunners for which i hear good feedback ,the car goes fine around 80-90km and then come back with smooth acceleration and have his problems with deviation.
its not something sill ylike the map sensor playing up is it? have you tried another one maybe?
(clutching at straws now)
Bill was talking about the map sensor. Its in your intercooler pipe work and detects the amount of boost being produced.
maf,map,sparkplug,coilpack,coolant temp sensor,lambda sensor,n75,hoses, turbo k03s. the result is the same 17963
