brad1
Hi all
I couldn't find an exact answer, but what's the standard boost in psi on a lcr??
Cheers :)
Does 13psi sound normal for a standard lcr, only mods I have are a custom back box and forge 007p
About right. After I posted I thought it might be 0.88bar not 0.8
0.88 bar would be 12.76 PSI according to google
(seriously, just type "0.88 bar in PSI" into google)
Which LCR do you have?? the 210 or 225? the 225 is 14 psi standard boost peak. the 210 i would say as previous 11 psi
Do you have a boost gauge?? you can check if you have a leak because the vac on idle will be 20 inhg
No. 210 and 225 run the same boost, I beleive.
What do you mean by 20inhg? Negative 20?
Only asking as i'm not sure if i've got a leak, i've got a boost gauge aswell. I get around 15/16psi on mine does that sound right for standard?
Boost is PSI which is pounds per square inch - posotive pressure
Vacuum is InHg which is inches of mercury - negative pressure
LCR is 12 to 14 psi
Essentially at low rpm, when you open the throttle a negative pressure is produced as the engine sucks air in. As this air exits the engine it turns the turbo, which speeds up until the negative pressure becomes positive. This should then increase in pressure to full boost, and if all is well stay at this level until you release the throttle.
If their is a boost leak, then this process will still occur, but some of the boost pressure will be forced out through the leak, so the pressure will not build as fast or as high as normal, hence the loss of response/power.
Hope this helps!
My 210 gauge show 20 inhg on idle but sometimes its a little higher 23 inhg. Is his right or do I have a vac leak.
Mine seems to read less since i fitted the 'no buzz' t-piece from Newsouth. It now reads about 15 on idle and boosts at about 11psi holding at about 10psi. It read a bit more either end before i fitted resricted t-piece. Has anyone else had a similar problem ?:confused:
Dammit, i knew i shouldn't have read this thread lastnight, car was fine yesterday, then tonight i noticed i was only only boosting to .5bar and when idle it sits at -8 on the guage, see below pic. the guage also seem erractic, so i thought it could be guage playing up.
would these be the symptoms of a boost leak
The only symptom of a boost leak is slower pickup and lower max boost with loss of power. If it's not reaching max boost then it's probably a leak. If the gauge bounces around alot then it's probably the gauge or installation - some makes are well known for this and for inaccurate gauge readings.
As to sitting at idle, if the vacuum figure is lower than normal (ie closer to 0), as a result of a fitting, I'd guess it shows the new part is less restrictive. Personally I wouldn't read too much into gauges not Reading spot on where they should be as they aren't all that accurate.
