Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Which LCR do you have?? the 210 or 225? the 225 is 14 psi standard boost peak. the 210 i would say as previous 11 psi
Do you have a boost gauge?? you can check if you have a leak because the vac on idle will be 20 inhg
sorry to hijack you thead but does any one know what standard LC boost is?
So if i've got a boost leak will it be above or below 20inhg?
My 210 gauge show 20 inhg on idle but sometimes its a little higher 23 inhg. Is his right or do I have a vac leak.
