James' LCR - 2008cc Stroker HTA GT3071r! - Tuned @ Badger5
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
As the car stands today, and a list of the parts installed / to be installed
Block
BAM Engine Block
92.8mm Forged Crank
1.8 Oil Pump Drive Gear
Mahle Motorsport Powerpak Pistons
Mahle Motorsport Piston Rings
Mahle Motorsport Wrist Pins
06a 1.8T Oil Squirters
DM Forged 144 x 20 Connecting Rods
ARP2000 Connecting Rod Bolts
Calico Coated Main Bearing Set
Calico Coated Rod Bearing Kit
ARP Main Bearing Stud Kit
OEM Head Bolts
HEPA Metal Impellor Water Pump
Gates Performance Timing Belt
9A Manual Tensioner
Contitech Serpentine Belt
Custom Made Oil Catch Can
Overbore Master Gasket Kit
New OEM Oil Pump
New OEM Oil Pump Chain
New OEM Oil Pump Tensioner
AKS Tuning Baffled Sump
Cylinder Head
ADR Large Port Cylinder Head - Ported & Polished
Cat Cams 3658 Billet Camshafts
Cat Cams Adjustable Cam Wheel
New Valve Guides
Ferrea F1556P 26.9mm Intake Valves (12)
Ferrea F1554P 29.9mm Exhaust Valves (8)
Ferrea S10055 Intake Valve Spring (12)
Ferrea S10056 Exhaust Valve Springs (8)
Ferrea SL1025 Intake Spring Seat Locator (12)
Ferrea SL1026 Exhaust Spring Seat Locator (8)
Ferrea E11031 Titanium Intake Retainer (12)
Ferrea E11032 Titanium Exhaust Retainer (8)
New Valve Stem Seals
New OEM Hydrualic Lifters
Turbo
HTA GT3071r Billet Wheel
Tial Vband Turbine Housing .82A/R
Tial 38mm MV-S External Wastegate
Manifolds
TSR Performance Tubular External Wastegate Manifold
SEM Motorsport Large Port Intake Manifold
Bosch 75mm DBW Throttle Body
INA Adaptor Plate
Fueling
Bosch EV14 750cc High Impedance Injectors
DA31 Fuel Pump
Exhaust
Custom Made Downpipe & Center Section by Badger5
Miltek Stainless Cat Back Exhaust System
Cooling
Forge Motorsport Big Race Intercooler
Intake
Custom Badger5 Billet Radius Stack (RS4 MAF)
6" K&N Filter
Chassis
Full KW V1 Inox Stainless Steel Coilovers
Full Superpro Bushes (Wishbones, Dogbone, Rear Axle, Steering Rack)
Vibra Technics Fast Road Engine Mounts
R32 23mm Front ARB
Drivetrain
Southbend Single Mass Flywheel
Southbend Stage 3 OFE Daily Clutch Kit
Southbend Stage 3 Pressure Plate
034 Machined Gearbox Linkage Bushes
Wavetrac 02M LSD
Brakes
Forge 6 Pot Calipers
Forge 356mm Floating Discs
Mapping
Badger5 Custom ECU Map
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
I like alot :)
The 2nd pic looks quite quaint but i'd love a yard like that.
JamJay,
Been reading through a few posts that you have put through to AmD, i'm thinking of getting some coilovers fitted (Weitec Hicon) and wondered what you are getting fitted? Are you doing the front Arb as well? :)
by the way mate forgot to tell you its got auto windows module fitted. just hold down the unlock on the key fob
Funily enough i was playing around with vagcom the other day turning on a few bits and noticed that it had auto closure when i was testing the key fob. Cheers for letting me know though. :D
Deleted member 20376
love the colour of your alloys, goes well mate, id like a similar colour on my black lcr
JamJay
California Bound
JamJay,
I am still considering these but I used a brand on a old car called K-Sport which were very good at a great price. They normally specialise in Jap Cars but they do a kit for the LCR for a tad over £600 supplied which is 36-way damping adjustable also. They were fitted for 2yrs and I never had a problem at all, not rust either, I think they were stainless steel. APEX Performance are the UK Supplier. I am not sure about the front ARB, I think it's quite capable but needs an upper strut brace to compliment it more than anything.
I would fit them myself but the price from AMD seems fair.
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
Are you fairly mechanically minded? Also, your not far from me :D
