As the car stands today, and a list of the parts installed / to be installed
Block
BAM Engine Block
92.8mm Forged Crank
1.8 Oil Pump Drive Gear
Mahle Motorsport Powerpak Pistons
Mahle Motorsport Piston Rings
Mahle Motorsport Wrist Pins
06a 1.8T Oil Squirters
DM Forged 144 x 20 Connecting Rods
ARP2000 Connecting Rod Bolts
Calico Coated Main Bearing Set
Calico Coated Rod Bearing Kit
ARP Main Bearing Stud Kit
OEM Head Bolts
HEPA Metal Impellor Water Pump
Gates Performance Timing Belt
9A Manual Tensioner
Contitech Serpentine Belt
Custom Made Oil Catch Can
Overbore Master Gasket Kit
New OEM Oil Pump
New OEM Oil Pump Chain
New OEM Oil Pump Tensioner
AKS Tuning Baffled Sump
Cylinder Head
ADR Large Port Cylinder Head - Ported & Polished
Cat Cams 3658 Billet Camshafts
Cat Cams Adjustable Cam Wheel
New Valve Guides
Ferrea F1556P 26.9mm Intake Valves (12)
Ferrea F1554P 29.9mm Exhaust Valves (8)
Ferrea S10055 Intake Valve Spring (12)
Ferrea S10056 Exhaust Valve Springs (8)
Ferrea SL1025 Intake Spring Seat Locator (12)
Ferrea SL1026 Exhaust Spring Seat Locator (8)
Ferrea E11031 Titanium Intake Retainer (12)
Ferrea E11032 Titanium Exhaust Retainer (8)
New Valve Stem Seals
New OEM Hydrualic Lifters
Turbo
HTA GT3071r Billet Wheel
Tial Vband Turbine Housing .82A/R
Tial 38mm MV-S External Wastegate
Manifolds
TSR Performance Tubular External Wastegate Manifold
SEM Motorsport Large Port Intake Manifold
Bosch 75mm DBW Throttle Body
INA Adaptor Plate
Fueling
Bosch EV14 750cc High Impedance Injectors
DA31 Fuel Pump
Exhaust
Custom Made Downpipe & Center Section by Badger5
Miltek Stainless Cat Back Exhaust System
Cooling
Forge Motorsport Big Race Intercooler
Intake
Custom Badger5 Billet Radius Stack (RS4 MAF)
6" K&N Filter
Chassis
Full KW V1 Inox Stainless Steel Coilovers
Full Superpro Bushes (Wishbones, Dogbone, Rear Axle, Steering Rack)
Vibra Technics Fast Road Engine Mounts
R32 23mm Front ARB
Drivetrain
Southbend Single Mass Flywheel
Southbend Stage 3 OFE Daily Clutch Kit
Southbend Stage 3 Pressure Plate
034 Machined Gearbox Linkage Bushes
Wavetrac 02M LSD
Brakes
Forge 6 Pot Calipers
Forge 356mm Floating Discs
Mapping
Badger5 Custom ECU Map
Block
BAM Engine Block
92.8mm Forged Crank
OEM Head Bolts
9A Manual Tensioner
New OEM Oil Pump
Cylinder Head
New Valve Guides
Turbo
Manifolds
INA Adaptor Plate
Fueling
DA31 Fuel Pump
Exhaust
Cooling
Intake
6" K&N Filter
Chassis
R32 23mm Front ARB
Drivetrain
Wavetrac 02M LSD
Brakes
Mapping
My dad is mechanic so I learn from him, i'm not scared to get my hands dirty.
