phil have you noticed any difference since you fitted it?
No oil in the pipes and intercoolers, when I took my single LC IC off when I fitted the twin LCR ones there was about half a litre of oil in it, when I did the front mount about 12 months later there was none in the intercooler and I don’t get the oily residue in the boost pipes now. So yes a difference :D
This is my new Catch Tank, i had it custom made it has two in takes not one so no need for the "T" piece and the exit to the tip there is a baffle infront of the exit to trap any oil vapours so they dont get in the system, i have tried both the tip exit and to atmosphere and the tip is better alo having it go to the tip helps with the breathing as the intake pulls the air from the tank so assists the flow from the crank.
About £45-£50
No thats what the problem was and why i had this made, all 19mm inlet and outlet no messing about 19mm all the way through.
How would I go about getting one of these 19mm inlet/outlet catch tanks?
Trying to find one is like trying find rocking horse...
i think will have the same probs , dont think the Greddy one is 19mm hoses
and if im thinkin rite , needs to be 19mm ina nd out ye ??
again if someone can clairfy & confirm the best place to get the hoses from
cheers
When bill took apart my turbo due to INA manifold cracking, there was a lot of oil down the pipes etc. Car is getting old now over 100k and def needs the catch can sorting. Which is being done in May time
Any chance Tony that you will let me know when you do it - so i can take a look ? If its not a problem maybe w could do it both at the same time ? :p
looking at that pic has made me want 1 , just out of curiousity like me i dont have a oil tank catch where would it go ? ... not back through my engine ?
