Which oil for ibiza cupra gearbox
Dan.Payne
249
Over The Rainbow
how did it come out - does it drain like oil or do you have to suck it out with some sort of tool?
cheers
dead easy, theres a 17mm hex bolt at the bottom of the gearbox to drain from an then at the front of the box is an identical 17mm hex bolt, requires a tool seen below
Oct 17, 2006
893
Walthamstow
will do mine this weekend - on 67k - along with the downpipe/cat
where did you buy the CASTROL SMX-S 75W-85 oil from? locally or delivered?
cheers
o and how many litres you put in there?
Dan.Payne
249
Over The Rainbow
cheers
No I used Redline MT90 oil in mine, and it took just under 2 litres. I bought mine from demontweeks.
Oct 17, 2006
893
Walthamstow
you can get the same grade gear box oil from local car places i would have thought - wanted to do mine this weekend aswell - tried euro but they dont do redline MT90
mali00
when is the recommended time-miles to change the gear box oil??
Mar 1, 2009
1,079
Liverpool
wouldnt want to do it on my back!
if you still have SMIC, its a ****.
bottom plug is easy, but filling it back up is gay! gotta remove the intercooler to get to the fill-plug.
Dont suppose you could point out the drain and fill points on this picture?
I need to do mine aswell, but havent a clue where the points are.
