As a few members have asked about this here is how to remove the rear bumper.
You will need a torx set for the screws and a small screw driver to flick the number plate light plugs off.
1. Start by opening the boot and pulling up the aperture seal on the boot
2. Remove both rear lights
3. Remove the screws from the inside each rear wheel arch
4. Remove the screws from the under side of the bumper
5. Remove the 6 screws (3 each side) that are under the rear lights
and then lift the bumper off (if you can get a friend to help it makes life a lot easier).
6. unclip the number plate light plug with a small screw drive and place bumper some where safe so it will not get damaged.
Job done
Job done
