st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
As a few members have asked about this here is how to remove the rear bumper.
You will need a torx set for the screws and a small screw driver to flick the number plate light plugs off.
1. Start by opening the boot and pulling up the aperture seal on the boot
2. Remove both rear lights
3. Remove the screws from the inside each rear wheel arch
4. Remove the screws from the under side of the bumper
5. Remove the 6 screws (3 each side) that are under the rear lights
and then lift the bumper off (if you can get a friend to help it makes life a lot easier).
6. unclip the number plate light plug with a small screw drive and place bumper some where safe so it will not get damaged.
Job done
Hi St10587,
I see you have helped describe the removal of the rear bumper I just wondered if you could tell me how to get the front fog lamp covers off as I need to replace the front grille due to a hole in it and not being very good with cars would not like to break anything while im attempting to replce it. I got the Ibiza 1.9 tdi FR 2004 plate.
Thanks in advance
Wayne
Hi St10587,
Thanks in advance
Wayne
Hi Wayne
there is a small screw in the top corner of each grille, remove this then they just pull out!
Steve
Thank you Steve,
I will have a go at this if it ever stops raining.
Regards
Wayne
Hi again Steve, I cannot seem to locate the screw can you give me an exact location or a pic............sorry to bother you but your the only one who has replied.
wayne
I think it does Steve thanks will have a look tomorrow.
Thanks again, sorry to keep pestering ya.
Wayne
Hi Steve,
Just to let you know all sorted thanks..
Wayne
Phew!!! Flamin firewall at work must block the pictures on the site.lol
Going to fit the towbar this weekend so wanted the guide to help me lol
Do you know which colour wires do what with regards to indicators etc??
there should be a wiring chart with the towbar
Sorry to bump an old thread but thank you for the info :D
Edit: Glad this is a sticky :)
Did this earlier and it's very useful :)
Just a note, the wheel arch screws are pretty hard to get to without taking the wheels off, I had to take mine off
Also with the new bumper make sure the screw adaptors are on the screw holes near the bottom else the screws won't fit
