vroomtshh
4,183
Dreghorn, Scotland
I have a jack, towing eye, locking wheel nut key and a small metal doofer that i have no idea what it is. Is thi the wheel nut cover remover? And if so, how does it work?
Should I have a screwdriver too?
Is it like a spring type jobber (it`s a word!), with a hook at one end?
You should have as you described plus a screwdriver with a switchable end and a spanner which is 10mm one end... and 13mm on the other end.
Does it look like this.. clicky
Yeah its the wheel nut cover remover, if you look closely at the cover you will see a small hole. Just put the hook end of the metal clip in there and pull :)
I dont have either of them Neo :( Got my own tools anyway..
You should also have the wheel nut wrench :rolleyes: Wouldnt be very good without that!
Thats the one
Yeah on your centre caps there should be a small hole, put the hook end in, turn it and with the round piece on your finger (like a ring) you should be able to pop the centre cap off.
If you have SEAT wheels of course lol.
So its a centre cap remover, not a wheel nut cover remover?
Actually, I was hoping it was a wheel nut cover remover :lol:
But I couldn't figure out how it woud remove them
Hehe
It`s very handy though, stops you scratching your wheels by using a screwdriver to get the caps off.
