Ok mate. It's annoying because Forge said that the 10mms should fit fine, but I'm not 100% confident about their answer.
I suppose I could whack them on the lathe at work, are you talking about making the pocket on the spacer that accommodate the hub rim deeper?
Spoken to Bill @ Badger5, helpful as ever!
He took a wheel off the back of the S3 that was in the workshop and measured the spigot and came to the conclusion that it's very unlikely that the 11mm Forge spacers will fit the back.
I'm now stuck in the predicament, 11mm front and 16mm rear. Or 16mm all round?
I really want the H&R spacers, but can't justify the cost. I think they are overkill and at the end of the day they are only wheel spacers
I'm going to order a pair of the ebay 15mm ones tomorrow, can someone tell me which type of bolts I need for OEM LCR wheels? Tapered or radius I think they're called?
