Thanks berg. Most people have the 20mm spacers so id thought i would try the 25mm, Not that much of a difference tho.
Hopefully the DV is a good improvement but not sure if i need to change to a yellow spring??
Intercooler should be here on monday at some point :)
You only need the yellow spring usually if your stage2 or running boost from 15-23 PSI
claire, do you think you will need any arch mods when you fit them spacers with those wheels? nice looking mk3 anyway and let us know how you get on with the roof lining.
Lovely car there, looks tip top and i'm sure it goes too :)
Ten times nicer than the Saxo
Keep up the good work
The psi pressures listed for the springs dont relate to boost pressure, its somethign to do with load pressure of the spring..confusing i know but could mislead people
Personally green is normal for stage 1 mods and it seems to be what most people use on here.
Wont need any modifying to the arches the car isnt lowered and when i do buy coilovers im not slamming it.
I will post pics of roof linen, soon as i get it done
Thanks. Yeah car goes rather well. Finally starting to mod it, to make it my own :)
Nice looking mk3 :thumbup:
You dont want to fit a 3" MAF otherwise it will screw up the fueling, unless your going for a hybrid turbo?
I will eventually be going hybrid throughout time. :)
Got decent plans for it, but if i find the stage2 being decent power i shall stay put, but thinking along the lines of audi s3 injectors. Hybrid turbo eventually and other stuff. I want the engine fully samco'd :D
Well dont go fitting a 3" MAF and/or injectors (both LCR/TT/S3) untill you do go hybrid.
There's no need for them for stage 2 ;)
I ran a yellow spring in my 007 on both stage 1 & 2 and found it great..
Nice wee touches to it. Like the colour of the wheels :)
If your ever though Glasgow way and want a LCR splitter for it give me a shout. Got one lying in the garage i'm not using and its only gonna go in the bin.
Will be getting fitted soon ;)
nice looking car :)
ive just fitted one of these kits myself, i would recommend changing the clips to mikalor type though as the ones in kit are rubbish
Nice update...now get it fitted :p
All i need are the aluminum pipes and hoses...for some reason the previous owner only ordered the hoses and they where the wrong size dia!! lol
