30 mpg thats good,im really starting to like these mk5 cupras more and more.
whats up with the ride is it rough like the standard mk4 cupra suspension?
Jiggley like the MkIV yes. Normal SEAT over sprung, under damped. It's fine when you're having fun, but just bimbling about it's not what you'd want for a long period
Not quite 2000 miles and we have flashy lights on the dashboard.
Call to the dealer tomorrow then.
Wednesday,02,March,2011,18:53:10:08176
VCDS Version: Beta 11.2.0 (x64)
Address 01: Engine Labels: None
Control Module Part Number: 03C 906 027 AE HW: 03C 906 027 AD
Component and/or Version: 1.4l R4/4V TS H12 6597
Software Coding: 00250012002400000000
Work Shop Code: WSC 06402 785 00200
ASAM Dataset: EV_ECM14TSI03C906027AE A01008 (SE25)
VCID: 64CCBDDCDC9B
2 Faults Found:
4054 - Cylinder 1: Misfire Detected
P0301 00 [101] - Short to Plus
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 3251 km
Date: 2005.14.19
Time: 17:59:30
4051 - Random/Multiple Cylinder Misfire Detected
P0300 00 [101] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 3251 km
Date: 2005.14.19
Time: 17:59:30
Readiness: 0000 0000
VW are currently doing a "product enhancement" (recall) on coil packs due to so many failures. You might just be in the dodgy batch!
Called the dealer..
Apparently "if you read on the internet" there are some issues.
My reply.... "yes, you mean on my website?"
Booked in for Monday
Nice one Mark. Must admit I was thinking of the possibility of having a new Ibiza myself, but not sure if I'd miss the extra room and doors. We'll see...
Dropped the Ibiza at Kings SEAT at 8am, and it was picked up 5hrs later with new spark plugs, a compression test, fuel pressure tested & a new ECU map.
I'd swear it felt a little faster on the run back to work
Over the weekend I noticed a little squeak under part load at about 3000rpm or so it's going back for round two on the 23rd to stay over
Water pump next then possibly? I think you are working your way through the list of things that were done to mine.:think:
It's not squeaked today - so maybe not
Awesome delivered a Rear ARB today, so I'll try to get that on at the weekend :)
Nope, no Mk4
I've fitted & driven one to a Mk4, and also various Leon's - so I'm interested in it too. Hopefully it'll take some of the numbness away
Rarb is a superb mod on the mk4. Turn in is so much better. Think mine is only on medium, very noticeable. What's feedback from the mk5 guys who have had them fitted?
Weitec coilovers should sort the ride. Nobody who "works" at Seat has ever driven on a British Road. And since most probably ride donkeys to work i doubt they have ever driven a car either.
