hi robbie hows it going? glad to see some progress coming along with this unlike my carlol cant wait to see this all done and getting used properly and to see where all your cash has gone lmao, what valves are you getting for it m8? read on your first post that your using ferrea valves but had no update on this on your readers rides and who's doing the fitting of the valves for you?
keep up the good work both you and dale
Cheers Gaz - yeah will be nice to get it back on the road to get some moneys worth out of all this, though it gives me a sound platform to build upon.
After talking with a few people and getting quotes for various different bits and pieces I've ended up ordering:
JE 82.5mm 9:1 CR pistons
Ferrea Super Alloy inlet and exhaust valves
Ferrea valve springs and titanium retainers
Uprated sputter big end bearings
ARP main studs
OE replacement main bearings, thrust washers, head bolts, head gasket kit and crank seals
As JE have to custom machine these pistons I'm waiting on these to be finished and shipped along with my Ferrea valve set which should be with me within the next couple of weeks.
In the end the Ferrea valvetrain came in only slightly more expensive than the Supertech set and I was advised that the angles on the Supertech valve bowls don't always match those in the cylinder head, sometimes resulting in the need to get them re-machined. Either way, the Ferreas ought to be more than capable and look like a very nice kit.
In the meantime my AYP head has been sent to JNL for porting and polishing while the block is away being rebored to 82.5mm ready for the new pistons. Further updates to follow when bits start arriving ready to be fitted.
i know the seal leon supercopa same as the cupra r racecars run the ferrea valves but bill runs supertech in his racecar so just wanted to know if there was any reason behind this?
says who?... I was advised that the angles on the Supertech valve bowls don't always match those in the cylinder head, sometimes resulting in the need to get them re-machined. Either way, the Ferreas ought to be more than capable and look like a very nice kit.
Robbie has been looking to the future with this engine build and going big turbo when funds allow so the engine has been built with function in mind for the 380bhp mark which is where the ported smallport is by far the best option.
Some of the newest turbos in development such as the 2283 hybrids and the new HTA offerings from Garrett that utilise a billet wheel for good spool whilst maintaining strong power right to the redline will suit me well.
