The reg. plate lights;
Spent some time doing the following (nothing too exciting I'm afraid);
Little niggles and rusted screws are becoming an issue when changing bulbs, pulling things off on this car. I've spent my scattered times off cleaning things, taking things off, putting them back on etc.
They were particularly annoying!
. Simply piloted a hole in the middle of the mashed screw, and took up the bit size accordingly (1.5mm, 2mm, 4mm), finally using a 5mm bit to eliminate the head, but small enough not to damage the hole in the light;
New bulbs fitted, then re-fitted with new self tapping screws. Good as new. It's all about the small things!
how could you say that tbh ime having enough problems with curbs at the mo to worry about spacers
