looking as good as usual phil, as said above more pics of the bay i need to see how you have moved your wires
I guess if you go largeport, I go ported small port it will be a great indication on flow when we compare logs....
6mm was the size spec'd by Tial and Greddy.
6mm from the turbo outlet to the boost solenoid (greddy) and 6mm out to the top port of the Tial. 6mm to the lower port on the tial.
Ive also used 6mm to the Forge Supersize valve from the inlet manifold as well.
stock size from inlet manifold to FPR.
Thanks all.
I'll take some pics this week when i do a little work to hide the catch tank (remove it lol).
