also just seen this on ebaay has used this TIP and can give any feedback on it as said before on a budget so not going to go mad on the forge and other pricey ones
tis for increased flow mr mark always better to have a good air flow as you know but jusy wanna know if its a good tip mine was £60 and is ok besides its been on his car for 9-10 years so could do with replacing
Bought one for my AUQ LC and fitted it last weekend. What a difference it made! Really pulls harder and for longer/higher in the rev range. Well worth it and really well made. Search Creations Motorsport on the Leon MK1 forum and there are a few people with them and all rate it. Some say better than Forge. I wouldn't argue especially at that price.
I wasn't knocking it, seems competitively priced to be honest. I think I saw these for sale last year on a stand at gti international and they looked pretty good.
Mine was a direct fit on the LC with an AUQ engine. T'was a pig to fit but only because it was difficult to get to turbo on mine. I've heard LCR's are easier but don't know about beezas. Drop em a message they get straight back to you.
Take all connections off old OEM tip like n75 & DV etc. Then disconnect the rubber hose from the metal pipe. Pull metal clip away at front and side at same time. Two people makes the job much easier. Then onto taking the metal pipe off.
When doing mine I found it easier to take the air box out. You can the see the turbo better and get in to reach it better. The original pipe is held in place by 1 Allen key bolt on top side. Undo this then wiggle old pipe away from turbo towards wheel arch. You can also get your arm down back of engine and just reach the turbo from behind too. Might need to ease the pipe away from turbo with a screwdriver to help prise it away. Once old pipe is off turbo you have to manoeuvre the pipe between engine block and a solid pipe (coolant maybe?) to get it out.
Once you do this you can start fitting your silicone tip. I rubbed a small amount of engine oil around the inside edge of tip where it attaches to the turbo. It is tight to get it on but if you put it down the gap between block and pipe so the turbo end points towards back of car then once pushed and squeezed through you can twist it over the flange on turbo. Feel all the way round to make sure it's on properly. I then undid a hose clip and looped it round before tightening it til it just grips. Make sure all connections are in right place and if happy fully tighten because it's hard to get to once other hoses are connected to it. Connect other hoses then refit airbox and connect to that. Start car rev a little just to check no leaks then take for a run. If you've no leaks or anything you will notice the difference.
Turbo spools 200-300 rpm sooner and keeps going until higher in the revs.
