Can you not take the crank sensor off your old engine, put on this engine, see if it does the trick.
Worth a try I guess?
right pulling hair out now changed it over from my old one and now no spark at all :(
anyone got any ideas ?
ignition switch faulty too + immobiliser fault?
a friend had a mk3 golf that just turned over and had no spark.. when he wiggled the key about whilst turning the engine over it worked.
i cant remember if you can adjust them on the abf? may of been the early 9a kr motors,, is it the two bolt jobby?
a strobe gun would be the best way i suppose, you have got the firing order correct? when it run, did it idle ok or rough ?
ok so i think is going to have to be wait untill mids vw can get her in or try and find somewhere local we can tow her too :cry:
does any one know about running a diagnostic , midland vw said they cant run one unless the car is running but a place we went to today said you could ?
you can..
it doesnt need to be running to be read up.. just flick the ignition on so it can communicate with the ECU :)
well she went doem at 8 30 this morning ang they are pritty sure it is the crank sensor so they have ordered one and it should be on for monday fingers crossed
