Spill the Beans, what manifold did you get? Also, good call with the Rods (ie?) they really do add peace of mind.
I do to be honest but nobody else does lol. It depends entirely on your supporting mods. I'll be somewhat disapointed if i don't but hey if you don't think champane you'll never drink it.Do you reckon 350's possible with the standard turbine wheel?? I cant wait too see what mine will make
A hybrid on its own is nothing more than a lively stock k04, you'll need the kitchen sink to break past the true 350's, i'll do itand it won't be ott boost either.
I've got an xs power mani to fit when the head comes off (sorry for the late reply Robbie) but i'm sceptical about its longevity but i have to give it a go. I'm happy with my setup as it is so the rest will be the icing for me.Be interesting to see what we both get. Im hopeing the fact im 1.9 and have a largeport head and inlet it will be able to use all the airflow created and not surge. HOPE anyway
Managed to pick up a ceramic coated INA manifold off a member on here, what manifold did you go for???
They're all warped to be honest, but since their stainless i can literally push them flat on a flat surface so i'm not overly concerned. Not the easiest manifold to fit but i'm confident.That was going to be my other option, are you going to get the flanges skimmed as they are normally warped from the welding?
Tbh anything over 300 and ill be happy, its only got to pull a little ibiza along!
We saw >260g/s from wellys often, BUT, it did not equate to power until the exhaust manifold was fitted and the thing could more efficiently flow that injested air and not just turn it into heat losses and pumping losses.
Excellent airflows for sure, but I do not see it making a real 350bhp no matter how hard you try..
from 22psi sustained boost and wmi, 338bhp/307lbft in sensible egt zone... (still high, just not insanely high)
more boost just got it to hot (yellow manifold!) - XS one
I'm interested in seeing how close mine will get to Welly's so that if nothing more we can see the contribution of the largeport head. I'll get my set up as strong as i can on the stock mani and i come and see you for a comparison RR run so i can quantify any gains after the manifold installation.We saw >260g/s from wellys often, BUT, it did not equate to power until the exhaust manifold was fitted and the thing could more efficiently flow that injested air and not just turn it into heat losses and pumping losses.
Have a look in the hybrid thread on Bill's section, its all in there mate and a very recommended read.Yeah I didnt think it through properly, of corse it will stay balanced if I just removed the hotside.
What did you do then, just flow the edges that were formed from boring it out? bare minimum amount?
Have you got any pics?
Here ya go:
http://www.seatcupra.net/forums/showthread.php?t=298190&page=11
Bill how hard is it to remove the hotside, just the bolts and actuator rod, i am going to port my V1 myself![]()
Cheers and this won't damage the turbine or anything, i.e i can just bolt it back together when done and fit it to the car?
@ Wild Willy, when do you reckon your be fitting your new goodies?
