Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
312mm setup from a TT or similar is the easiest to source and fit TBH.
Am I right in thinking this a 1.4? As you'll need new hubs for the 312 TT brakes IIRC?
If your front discs are 288mm standard, then the 312mm TT upgrade is do-able. If you've got 256mm front discs like me, you're screwed and need new front hubs. Don't bother with that, just some quality discs and pad combo.
Momo is on:
How did you get your steering wheel off? ive dented my Seat logo on mine and need to get it off to push it back out!
Hi Jordan.
The best guide I can think of is available on the following link:
http://www.*******.com/forums/viewtopic.php?f=13&t=3626
I started a thread asking how to remove the steering wheel on IOC and a friend posted the guide from haynes manual. Good luck.
Air on it? Or just a random shot?
Just had a read thru your thread mate, like it alot. Glad all the Ibiza boys have the right idea slammed FTW
Air ride should be awsome, seeing so much more of it now
Are you fitting the kit yourself mate or getting some one else in??
