I never got mine working, just beeps, thats it.
Weirdly the windows do go up and down with the key in the lock
like this
Put your key into the ignition and turn the ignition switch to "ON", there is no need to start the vehicle
Plug the KVW100 into your OBD-II interface plug. Make sure it is a snug fit. The KVW100 will give a single long beep, once it is fitted properly
When the green led light on the KVW100 is on, hold the drivers door "lock" button
When you hear a long beep from the KVW100 again, release the door "lock" button
Wait for 2 minutes you will hear kvw100 give 3 short beep then pull it out (using the same USED kvw module originally used)
HTH![]()
umm, im afraid i dont know the answer to that, i dont even know if you can get them anymore. your best bet is to email the guy, contact details on this page. they are really helpful guys from what i can remember (this thread is quite old now)
Could think about this module http://autowindow.tripod.com/products.html#SEC5 folds the mirrors too £74 delivered
