like this
Put your key into the ignition and turn the ignition switch to "ON", there is no need to start the vehicle
Plug the KVW100 into your OBD-II interface plug. Make sure it is a snug fit. The KVW100 will give a single long beep, once it is fitted properly
When the green led light on the KVW100 is on, hold the drivers door "lock" button
When you hear a long beep from the KVW100 again, release the door "lock" button
Wait for 2 minutes you will hear kvw100 give 3 short beep then pull it out (using the same USED kvw module originally used)
HTH ;)
sorry to dig up an old thread.
i had a kvw100 installed in my 2005 . matched a new remote key today and now the auto close function has stopped working. the windows will go up but you have to hold the lock button whereas before just pressing it once would close the them.
i tried the above to uninstall it but it dose not work. turn on the ignition, plug in the kvw and it gives a long beep, wait for the light to come on then hold the lock button on the remote, gives a series of beeps not a long beep like when i put it in first??? waited 5 mins and nothing:cry:
found this guide http://www.ecstuning.com/stage/edoc/KVW100-Install.pdf
it says to hold lock till it beeps then unlock till it beeps then wait for 3 beeps. every time i try this it just stays beeping insteed of 3 beeps.. do i need to get a new one to get the windows to auto roll up??
umm, im afraid i dont know the answer to that, i dont even know if you can get them anymore. your best bet is to email the guy, contact details on this page. they are really helpful guys from what i can remember (this thread is quite old now)
tried to email them. got this back
Hi. This is the qmail-send program at mail4.eb.com.cn.
I'm afraid I wasn't able to deliver your message to the following addresses.
This is a permanent error; I've given up. Sorry it didn't work out.
<[email protected]>:
user is over quota
+a copy of what i sent. i tried to add keys with vagcom and cant do that either.
you can use other free software now to code windows up on keyfob a thread on here somewhere
you have to hold the unlock or lock button to open or close
if you really want it all, use autowindows thingy and can do mirrors and much much more at same time
kvw100 is also know to stop some functions in the ccm from working
ya i since i programed in the new remote the kvw100 has stopped working right. it use to roll up the windows when you pressed the lock button now i hav to hold it dowm.. that auto windows thing sounds good. where can i get that?? wonder will it work with the kvw100 acting up??
