Not 100% sure yet but I think iv sorted a cr turbo hybrid
So am going to be doing my rods
Iv been waiting for you to post on here again as i know you have rebuilt your engine
How did you find it ?
Ah I thought you meant a big big turbo!
I have been playing with engines since I was about 15 so I have a bit of confidence. Although the 1.8t is very much a learning curve for me.
There is a very big difference between putting an engine together and putting an engine together right. (as I have found out from the last muppet who built my engine lol)
Best advice I can give if its your first time is take your time and check everything twice.
You will need to know all the tolerances for the engine so you can check if anything is overly worn or knackered completely, and have the right tools for the job to make your life alot easier!
Its all good fun though mate :) Best of luck
Thanks for that mate no doubt ill be asking for some advice soon about something
Iv never really looked into a big big turbo as I thought they were mega bucks
Great thread mate, just read it all :) I live just down the road from you (truro), havnt seen you around though!
Best advice I'd give you if you're doing it for the first time is get opinions from more than one place before make major decisions and have the confidence to just give it a go. Message me if you need any specific details, I have certain measurements which might be handy.
Thanks mate never seen you about either
I'm always in truro shopping with the Mrs to
Only just got the car and learning to drive so its a rare occurrence for the ibiza to be out atm. Just passed my theory today so hopefully will get main test done soon :happy:
My dad works in falmouth so you may of seen him around, hes got a white renault megane sport 250 11 plate
Yea think I have seen that around
Little update
Cars now of the road untill end of January picked myself up a really cheap run about car
Watch this space as engine will be out soon
Ok so started work today on the car here's a couple of pics
An old freind lending a hand
Well while my car is of the road for the next 3 months im am going to be rebuilding my engine, putting hybrid turbo on, relocating battery,fitting oil catch can also fitting new engine mounts most probally
heres what im hoping to fit
DM Forged - 144|25|19-T or 144|25|20-S Connecting rods w/ ARP 2000 Bolts
elring 82mm max bore head gasket kit
Gates Performance timing belt kit
OEM replacement head bolts
KS connecting rod bearings
Piston rings
Bigend bearings
Gaskets (exhaust, inlet, & rocker cover)
Manifold nuts
Cambelt Tensioner
Manifold to turbo gasket (k03)
Turbo to downpipe gasket (k03)
Oil return to sump gasket
Oil return to turbo gasket
Miltek downpipe and sports cat
K03s hybrid turbo
Going to send my manifold of to bill to be ported to
LCR injectors and new injector seals
Lcr maf
helix racing vr6 clutch and lightened G60 flywheel
Im also going to be painting the block and powder coating the inlet manifold and rocker cover
WMI could be on the cards to
Probally a few other bits but cant think right now
comments please:)
Where did you get them mate you got a link?
Also when removing the air-con what belt do I need and can I just unbolt the bit attached to the bulkhead and just remove that??
Would you remove the secondary air pump to??
No link - I bought direct from VT themselves. I haven't actually removed the whole lot just the main pipe so not sure on what belt to get.
You can do what I did and remove the pipes are the bulkhead yeah - it's high pressure gas and extremely toxic stuff too so don't go breathing it it.
I removed mine ages ago now - I would do it yes, clears up the bay.
