correct type of flip key for the bezza? http://www.ebay.co.uk/itm/390374919593?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Looks to be! How are you going to cut the key? I found that key cutting places can't do it. if you have a look on wrayvon's thread I've posted a link to the guy I used. He got it right first time and supplied the blade. He uses your reg number and an automated machine which cuts it perfectly.
Sent from my BlackBerry 9800 using Tapatalk
I used timpsons aswell, when I eventually found one that thought they could do it, he said 'if it doesn't work, which it may not, there's nothing you can do I can't refund you'
Surprise surprise it didn't work. Spoke to this guy and it was perfect. He does it the same way a dealer would, using vin number and his machine knows the pattern so it comes out perfect.
If you do use him then get it sent to a friends address, the guy can cut a key for your car, and knows where you live if you have it sent to yours, may be an invitation to have your headunit nicked! Just a precaution!
Yes. My 3 button key works, so does my standard old 2 button onewould a 3 button work if i only had a 2 button to begin with?![]()
They do work, its just some people don't know how to use the 3 button keyI've read the unlock & lock buttons work, but have heard mixed views on the boot...
ah cheers for the help guys but as i alrady have a working keyim going to focus on power/torque
Milltek full de-cat exhaust
Pipercross induction kit (with cold air feed)
Remap
Braided brake lines (HEL)
bigger brakes
reccomendations for brakes?
Common on here for people to go for TT 312mm brakes.
What do you need braided lines for?
Where on earth are you getting the money to put 1.5k+ of mods onto your new FR?! You're 18 for god's sake!
I'm so jealous!
