And on the down side of things, the head was removed ready to fit the IE rods i have, the plan was quick skim, head back on then turbo etc on get it running, and in the mean time start building a 2.1-2 lump with head to suit (supertech throught , etc) but this is what we found on removing the head
[/IMG]
One cracked exhaust valve on cylinder 2.
[/IMG]
[/IMG]
And all 4 spark plugs are missing small bits of ceramic (not that clear in pictures but you get the idea)
And just incase anybody noitices the oil wetness in the pics it not a
problem with the engine it were i put the head on its side and oil ran everywhere,
So my main concern with this is the cause of it, to much heat i'm guessing is the main factor but is it from a possible mapping issue bearing in mind the car was only running a K03 so should not push stock valves etc to the limit?
And then there is the question of what do i do to sort it, i have both small (AYP) and large (ADR) port heads sitting here so i could do an all out build with supertech etc on either of thoses but not sure wich one will best suit the car (large port "V" small port) bearing in mind its intended use a a 1/4 mile toy?
Or i could just replace the one (or the full set of exhaust valves maybe?) valve with another stock one and hope its last untill the 2l lump is sorted but that could be well over 12 months or more?
Any thoughs or comments, advice etc much appreciated people!
