I do Fancy Rebuilding it my Self....or Learn too...But I wouldnt fit or time the cams up but just fit the valves...
Ie Slide the valve through the hole then spring on and cap....use compression tool then fit collets and slowly wind the tool out...Sounds simple but i know it isnt
Just Setting out to have a Bash at these...
This is the Valve spring Cut out?
25minutes later and a full on domestic with the Missed:
Double Check and this is how it should be sat?
