This should clear it
ill flick the switch for ya!!
thannks berg thats a good picture to work it out cheers
ok Berg, nice one :thumbup:
can be this hose, which go in oil catch tank, go for example in pet bottles or anything else?
or go for example under the car in the atmo?
Question, how much pressure is there in oil breather system?
earlier today, gave car some and when i got back oil splatter all over abs pump/ tip, the oil catch can sits just above abs pump and thatwas soaked, looked more oilly than soupy :s
f you found one with 3 ports you wouldnt need a t-piece no
Was my plan but i bought a 42 draft can from awesome in the end, has the correct size 19mm ports and is baffled etc
If you used a 90 degree straight off the rocker you can pretty much hide the t-piece
Yeh ive found 1 mate, looks the doggs
all ports are 19mm & baffled
