where do you plumb your catch tank into
Aug 27, 2010
893
This should clear it
ill flick the switch for ya!!
thannks berg thats a good picture to work it out cheers
adulka
116
ok Berg, nice one :thumbup:
can be this hose, which go in oil catch tank, go for example in pet bottles or anything else?
or go for example under the car in the atmo?
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Question, how much pressure is there in oil breather system?
earlier today, gave car some and when i got back oil splatter all over abs pump/ tip, the oil catch can sits just above abs pump and thatwas soaked, looked more oilly than soupy :s
Apr 15, 2009
2,189
Midlands
f you found one with 3 ports you wouldnt need a t-piece no
Was my plan but i bought a 42 draft can from awesome in the end, has the correct size 19mm ports and is baffled etc
If you used a 90 degree straight off the rocker you can pretty much hide the t-piece
R4cup
Beef NO Burger
Jul 28, 2006
1,757
In the garage
Yeh ive found 1 mate, looks the doggs
all ports are 19mm & baffled
