130 tdi slow start when warm
.Si.
562
sunny essex
got a seat ibiza 130 tdi sport..
its fitted with the asz engine..
now when its cold.it starts fine..run the car about and when its up to temp,and if i shut the engine off,it takes awhile to start
if i use the car for a few min,from cold it will start fine.
its just when its hot,that its becoming a pig...it does start..but you can crank it for about 5 or so secs before it fires.
go no other issues,no lights up..nothing.
could it be glow plugs..?
someone on edition 38 mentioned it could be starter motor related
any help please
cheers si
Mar 25, 2009
1,245
bath
It shouldn't take 5 seconds to crank, is it really that long or just feels it?
People always moan about the pd130's slow hot start. Some people have cleaned up/replaced the battery terminals and evidently that's fixed it. I think it's just their nature
.Si.
562
sunny essex
it feels longer..but ive timed one of them at around 5 seconds.
it never use to do it..never had the prob on my golf or bora 130 tdi's
joop200789
330
Barnsly
I've had the same problems with mine same as you discribe
I changed the coolant temp sensor to start with was an improvement but not fully cured it
Then I need to replace the battery anyway later on in the year and that sorted it out not had the problem once in the last six
Also read some where that when the engine is warm it needs x amount of rpm before it will start and a week battery/starter motor it can't turn the engine over fast enough to reach the required rpm
.Si.
562
sunny essex
ive replaced the temp sensor earlier this year with a vw one..so i dont think its that.
but someone said about the starter..
if it was a battery..why would it do it when warm..surley when warm it would have had a good charge
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
This fault is common across the VAG range and commonly down to the starter breaking down when hot. There is a modification that can be done in the software to overcome this, I've done a few and it works very well, but this is just a way to mask the actual issue.
.Si.
562
sunny essex
__________________
cheers fella
i should have said..when i try start it when warm.it turns over ok.just doesnt seem to fire.
it doesnt turn over any slower..well not that i can tell.,compared to when cold
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
Temp sensor.
There is more than one temp sensor. I think the fuel temp sensor going faulty causes poor warm starting.
Coolant temp sensor, fuel temp sensor, ehaust gas temp sensor, inlet temp sensor? And probably more too
Jan 11, 2005
680
Barnsley
Had the same issue before I replaced battery. New battery fitted, starts on the first crank. I also cleaned the earth terminal so that may have helped as well
Blanco92
www.racedriversinc.com
Apr 11, 2010
2,496
Bournemouth/Cheshire
Was going to say battery, my old Octavia TDI did this when I bought it, always started perfectly from cold but it would take a while to fire when warm. It was a bit embarrassing at petrol stations!
Turned out that it had the wrong rating of battery on it. New, correct one fitted and it was spot on.
I think the reason it didn't have the problem from cold is because when its cold the glow plugs would work to aid starting and they masked the problem. But when warm, the glow plugs didn't work, thus relying on the battery. Could be all wrong but its my theory!
