Polybushed my front bottom arms as one of the rear bushes failed the other day, seriously impressed with the difference. Much more positive in the corners when on a "progressive" drive.
Also did a quick clean up and lacquer of my brembos, no longer pink :p
I used Mercedes Benz aerosol type lacquer, partially because I know it can take a bit of heat but mainly because I work for Merc and we've got dozens of the stuff sitting :p.
sprayed the little ring around the gear knob and i switched the polarity in the fogs so i could run LEDs then im off to get them tinted yellow and maybe my mirrors wrapped :)
Ah right, alright for some eh ;) need to find the right lacquer as I doubt halfrauds stuff can take the heat... unless anyone can tell me otherwise that is.
Finally sorted with a blacksmoke remap this morning since my galletto lead arrived.
Noticable improvement from the word go, and serious pull. Car feels much faster.
A little anxious how this will effect my fuel consumption though. :think:
Forget fuel consumption, just hope it doesn't destroy your rods or turbo! :whistle:
Took my mates Cupra for a spin to the garage to collect his sisters motor and F**king hell i want a petrol one to compliment my 150diesel. Straight through exhaust is mint.
Sent from my GT-I9100 using Tapatalk 2
Timing belt, waterpump and alternator tensioner changed at mates rates :) and I then changed the oil, oil filter and pollen filter in the snow.
Excuse the lack of quality,
Before:
200.5 hp
190.7 pounds feet
0.75 bar boost
22mpg
After:
223.3
263.8 lb ft
1.25 bar
Mods:
split r
Universal open cone
N112 + n249 delete
I'm pretty chuffed for a stage one:)
Will be interesting to check the fuel consumption...
