vagman2001
89
Saturday 25 May 2013 19:29:50:32264 VCDS Version: Release 11.11.3 Data version: 20120401
1ML 906 032 A 1.8l R4/5VT 0001
Group A: '003 Group B: '115 Group C: '020
Engine Speed Mass Air Flow Throttle Valve Angle Ignition Engine Speed Engine Load Boost Pressure Boost Pressure Timing Retardation Timing Retardation Timing Retardation Timing Retardation
TIME (G28) Sensor (G70) Timing Angle TIME (G28) (specified) (actual) TIME Cylinder 1 Cylinder 2 Cylinder 3 Cylinder 4
Marker STAMP /min g/s % °BTDC STAMP /min % mbar mbar STAMP °KW °KW °KW °KW
0.3 760 2.72 0.4 5.3 0.6 760 18 1000 1000 0.02 0 0 0 0
1.22 760 2.72 0.8 5.3 1.49 760 18 1000 1000 0.9 0 0 0 0
2.14 760 2.72 0.4 3 2.51 760 18 1000 1000 1.81 0 0 0 0
3.11 760 2.69 0.8 3 3.41 760 18 1000 1000 2.81 0 0 0 0
4.04 760 2.75 0.8 23.3 4.31 960 37.6 1000 1000 3.71 0 0 0 0
4.92 2160 14.19 8.6 31.5 5.23 2160 15.8 1000 1010 4.61 0 0 0 0
5.82 1480 4.75 2.4 -6 6.16 1240 16.5 1000 1010 5.53 0 0 0 0
6.72 1040 3.47 1.6 2.3 7.03 1000 16.5 1000 1010 6.44 0 0 0 0
1 7.63 840 3.11 0.8 -3 7.93 800 17.3 1000 1010 7.33 0 0 0 0
8.53 760 2.5 0.4 3.8 8.84 760 17.3 1000 1010 8.23 0 0 0 0
2 9.44 720 2.61 0.4 4.5 9.75 720 18 1000 1000 9.16 0 0 0 0
Saturday 25 May 2013 19:31:28:32264 VCDS Version: Release 11.11.3 Data version: 20120401
0.37 760 2.78 0.4 -3.8 0.67 760 17.3 1000 1010 0.01 0 0 0 0
1.28 1040 3.56 1.6 -11.3 1.59 960 21.1 1000 1010 0.97 0 0 0 0
2.17 800 2.75 0.8 1.5 2.47 760 17.3 1000 1010 1.87 0 0 0 0
3.1 1160 5.14 2.7 13.5 3.39 1160 33.1 1000 1000 2.78 0 0 0 0
3.99 1120 13.61 10.6 17.3 4.31 1360 63.2 1000 1010 3.68 0 0 0 0
4.93 1840 15.5 9.8 27 5.21 1800 24.1 1000 1050 4.6 0 0 0 0
5.8 1360 3.83 2 -6.8 6.1 1280 18 1000 1020 5.51 0 0 0 0
6.71 1280 7.03 4.3 26.3 7.01 1320 27.8 1000 1010 6.4 0 0 0 0
7.61 1440 7.47 4.7 27.8 7.91 1480 26.3 1000 1010 7.31 0 0 0 0
8.51 1560 7.44 4.7 29.3 8.81 1600 24.8 1000 1010 8.22 0 0 0 0
9.41 1640 11.31 7.8 30 9.72 1760 72.9 1940 1000 9.12 0 0 0 0
10.32 2120 40.08 92.2 18 10.63 2360 96.2 2340 1200 10.03 0 0 0 0
11.23 2840 78.56 100 10.5 11.53 3160 145.1 2380 1760 10.96 0 0 0 0
12.14 3920 177.5 100 3 12.44 4520 191.7 2550 2540 11.84 0 0 0 0
13.05 5400 201.56 100 9.8 13.34 5440 191.7 2520 2220 12.74 4.5 4.5 1.5 2.3
13.95 6120 205.11 99.6 11.3 14.25 6280 169.2 1000 2060 13.65 3.8 4.5 0.8 2.3
14.85 5520 5.33 7.5 6 15.16 5080 14.3 1000 1150 14.55 0 0 0 0
15.78 3920 8.5 5.5 3 16.06 3720 12 1000 1060 15.48 0 0 0 0
16.66 3360 8.44 5.1 2.3 16.97 3240 12.8 1000 1050 16.39 0 0 0 0
17.57 3000 7.72 4.3 2.3 17.91 2880 13.5 1000 1040 17.26 0 0 0 0
18.57 2600 6.86 3.9 0.8 18.87 2560 13.5 1000 1030 18.26 0 0 0 0
19.49 2480 6.33 3.5 0 19.78 2440 13.5 1000 1020 19.18 0 0 0 0
Saturday 25 May 2013 19:37:24:32264 VCDS Version: Release 11.11.3 Data version: 20120401
1.08 2400 8.31 5.1 34.5 0.32 2440 17.3 1000 1020 0.72 0 0 0 0
1.98 2520 48.22 96.1 22.5 1.38 2400 17.3 1000 1020 1.68 0 0 0 0
2.9 2840 86.81 100 15.8 2.32 2600 100.8 2320 1240 2.59 0 0 0 0
3.79 3400 156.47 100 4.5 3.2 3000 163.9 2360 1960 3.49 0 0 0 0
4.81 4120 171.75 100 6 4.1 3600 191.7 2470 2540 4.47 0 0 0 0
5.71 4760 187.64 100 7.5 5.11 4360 191.7 2540 2540 5.4 3 0 0 3
6.61 5240 198.03 100 9 6.02 4920 191.7 2530 2380 6.34 5.3 3 3 2.3
7.52 5720 205.11 100 8.3 6.91 5440 191.7 2510 2250 7.21 5.3 3 3 2.3
8.44 6120 207.08 100 9 7.82 5880 184.2 2490 2200 8.12 4.5 2.3 6 2.3
9.35 6440 204.64 100 12 8.72 6240 175.2 2400 2120 9.02 4.5 2.3 6 4.5
10.23 6720 204.89 99.6 12 9.63 6560 160.9 2260 2140 9.95 7.5 1.5 5.3 4.5
Saturday 25 May 2013 19:40:13:32264 VCDS Version: Release 11.11.3 Data version: 20120401
0.7 2680 55.22 95.3 24 0.01 2520 29.3 1000 1010 0.35 0 0 0 0
1.66 3040 121.03 100 5.3 1.06 2800 113.5 2330 1390 1.37 0 3 0 0
2.59 3680 165.31 100 3 1.96 3240 191.7 2410 2480 2.26 0 3 0 0
3.47 4320 178.06 100 6.8 2.86 3920 191.7 2550 2540 3.17 0 2.3 3 0
4.37 4880 189.22 99.6 7.5 3.77 4520 191.7 2550 2500 4.08 3 2.3 3 3
5.28 5400 201.56 100 10.5 4.7 5080 191.7 2530 2330 4.98 6 1.5 2.3 3
6.18 5840 203.78 100 6.8 5.6 5560 185.7 2500 2230 5.88 6 3.8 5.3 6
7.2 6200 207.42 99.6 6 6.49 5960 178.2 2480 2180 6.9 5.3 3.8 5.3 6
8.1 6560 207.08 98 12 7.49 6320 170.7 2400 2190 7.8 5.3 3 4.5 8.3
9.01 6840 206.28 98.4 10.5 8.4 6640 149.6 2210 2110 8.72 4.5 3 4.5 8.3
Got it i think!!
Group A: '003
Group B: '115
Group C: '020
0.35 0 0 0 0
1.37 0 3 0 0
2.26 0 3 0 0
3.17 0 2.3 3 0
4.08 3 2.3 3 3
4.98 6 1.5 2.3 3
5.88 6 3.8 5.3 6
6.9 5.3 3.8 5.3 6
7.8 5.3 3 4.5 8.3
8.72 4.5 3 4.5 8.3
Code:
Got it i think!!
	Group A:	'003
Group B:	'115
Group C:	'020
0.35	0	0	0	0
1.37	0	3	0	0
2.26	0	3	0	0
3.17	0	2.3	3	0
4.08	3	2.3	3	3
4.98	6	1.5	2.3	3
5.88	6	3.8	5.3	6
6.9	5.3	3.8	5.3	6
7.8	5.3	3	4.5	8.3
8.72	4.5	3	4.5	8.3
wrap
Code:
 around them
Also we have no idea what car/mods you got. fill in your signature with info
Thanks LEE...I had a search about signature just there it's not on my edit list under user cp is it minimum 20 posts or 15?
Anyway I have an lcr with 007 with revised piston and n249 bypass I only bought the car a few weeks ago and I was told its not mapped but by the look of that I think it is and would I be right in saying not mapped very well?
I'm living in Ireland the last owner took it in from uk 3 years ago.
206 g/s through the maff is about 260 horses so definitely seems mapped, although not gospel it is a good indication
That's what I thought alright, does the boost pressure not seem too high tho? Indicating a bad map!
not from what i can see, my mates s3 (same engine) always requested 2550mbar and his was mapped so looks ok
altho im sure one of the tuners will be able to give it a once over too
It is mapped, my Revo stage 1 LCR requests 2550 mbar or thereabouts. Yours isn't sustaining that level of boost tho, it peaks about that then tails off a bit as the revs increase. Possibly a boost leak somewhere. It's also pulling timing at mid to high RPM (block 020).
If possible, log blocks 001, 030 and 112. What gear did you run the logs in?
Ran them in 3rd gear, I can log those tomorrow and post them up!
What would cause the timing pull?
4th is better if you can do that, you'll need a stretch of private road or runway tho cos redline in 4th is about 120 on the speedo.
Timing pull (or rather, correction) is caused by knock/pre-detonation. This is when the fuel/air mixture in the cylinder detonates too early. The ECU delays (retards) the ignition spark a little to compensate - you see that on block 030 for each cylinder.
When were your plugs last changed?
Is up to 6 acceptable or should they all be 0? I was due to change them yesterday but my local motor factors had no bkr7e's in stock so ill be changing them tomorrow...I had a quick look there the plugs that are in it are denso pk20pr-p8 and probably in the car 12k miles could that be a part of my problem?
Find out the ron mate. If its mapped for 98/99 ron but the fuels 95 it will account for high pull.
Something to rule out.
If you can find a local garage with a smoke machine its worth getting the vac and boost pipework tested for leaks. :)
It's rated 99 but probably more 98. I have not got a clue what it's mapped for is there any way I can find out?
Trying to find out who has a smoke tester in Dublin could be tricky!!
You want NGK BKR7EIX plugs, made a difference in CF's on my Revo stage 1 car. I don't know what Denso plugs are like when they are working right but I chose NGK over Denso after reading a couple of horror stories about Densos.
In an ideal world you'd see no CFs at all. What they mean is as described above - the map, fuel and ignition systems are being run too high and you're getting pre-detonation, this results in the car cutting ignition timing back for safety and making less power. As Pat says this could be as a result of poor quality fuel too. I'd change the plugs and switch to Shell V-Power fuel.
If you can find a Revo dealer try asking them if they can tell you if it's a Revo map on the car. Either that, or find someone who has the Revo SPS switch and a laptop, they should be able to suss it out. If it is Revo then it could just be set to run a bit too much timing advance and/or boost.
I picked up plugs yesterday so gonna fit them this evening along with an air and fuel filters, we don't have shell here the best seems to be maxol.
There is a guy Joe Power over here I think he mapped robs car on here maybe I should get it over to him and see what map it has!
Ill log 001, 030 and 112 and ill post them up here!
Thanks for the input 8bit!
