Saturday 25 May 2013 19:29:50:32264 VCDS Version: Release 11.11.3 Data version: 20120401
1ML 906 032 A 1.8l R4/5VT 0001
Group A: '003 Group B: '115 Group C: '020
Engine Speed Mass Air Flow Throttle Valve Angle Ignition Engine Speed Engine Load Boost Pressure Boost Pressure Timing Retardation Timing Retardation Timing Retardation Timing Retardation
TIME (G28) Sensor (G70) Timing Angle TIME (G28) (specified) (actual) TIME Cylinder 1 Cylinder 2 Cylinder 3 Cylinder 4
Marker STAMP /min g/s % °BTDC STAMP /min % mbar mbar STAMP °KW °KW °KW °KW
0.3 760 2.72 0.4 5.3 0.6 760 18 1000 1000 0.02 0 0 0 0
1.22 760 2.72 0.8 5.3 1.49 760 18 1000 1000 0.9 0 0 0 0
2.14 760 2.72 0.4 3 2.51 760 18 1000 1000 1.81 0 0 0 0
3.11 760 2.69 0.8 3 3.41 760 18 1000 1000 2.81 0 0 0 0
4.04 760 2.75 0.8 23.3 4.31 960 37.6 1000 1000 3.71 0 0 0 0
4.92 2160 14.19 8.6 31.5 5.23 2160 15.8 1000 1010 4.61 0 0 0 0
5.82 1480 4.75 2.4 -6 6.16 1240 16.5 1000 1010 5.53 0 0 0 0
6.72 1040 3.47 1.6 2.3 7.03 1000 16.5 1000 1010 6.44 0 0 0 0
1 7.63 840 3.11 0.8 -3 7.93 800 17.3 1000 1010 7.33 0 0 0 0
8.53 760 2.5 0.4 3.8 8.84 760 17.3 1000 1010 8.23 0 0 0 0
2 9.44 720 2.61 0.4 4.5 9.75 720 18 1000 1000 9.16 0 0 0 0
Saturday 25 May 2013 19:31:28:32264 VCDS Version: Release 11.11.3 Data version: 20120401
0.37 760 2.78 0.4 -3.8 0.67 760 17.3 1000 1010 0.01 0 0 0 0
1.28 1040 3.56 1.6 -11.3 1.59 960 21.1 1000 1010 0.97 0 0 0 0
2.17 800 2.75 0.8 1.5 2.47 760 17.3 1000 1010 1.87 0 0 0 0
3.1 1160 5.14 2.7 13.5 3.39 1160 33.1 1000 1000 2.78 0 0 0 0
3.99 1120 13.61 10.6 17.3 4.31 1360 63.2 1000 1010 3.68 0 0 0 0
4.93 1840 15.5 9.8 27 5.21 1800 24.1 1000 1050 4.6 0 0 0 0
5.8 1360 3.83 2 -6.8 6.1 1280 18 1000 1020 5.51 0 0 0 0
6.71 1280 7.03 4.3 26.3 7.01 1320 27.8 1000 1010 6.4 0 0 0 0
7.61 1440 7.47 4.7 27.8 7.91 1480 26.3 1000 1010 7.31 0 0 0 0
8.51 1560 7.44 4.7 29.3 8.81 1600 24.8 1000 1010 8.22 0 0 0 0
9.41 1640 11.31 7.8 30 9.72 1760 72.9 1940 1000 9.12 0 0 0 0
10.32 2120 40.08 92.2 18 10.63 2360 96.2 2340 1200 10.03 0 0 0 0
11.23 2840 78.56 100 10.5 11.53 3160 145.1 2380 1760 10.96 0 0 0 0
12.14 3920 177.5 100 3 12.44 4520 191.7 2550 2540 11.84 0 0 0 0
13.05 5400 201.56 100 9.8 13.34 5440 191.7 2520 2220 12.74 4.5 4.5 1.5 2.3
13.95 6120 205.11 99.6 11.3 14.25 6280 169.2 1000 2060 13.65 3.8 4.5 0.8 2.3
14.85 5520 5.33 7.5 6 15.16 5080 14.3 1000 1150 14.55 0 0 0 0
15.78 3920 8.5 5.5 3 16.06 3720 12 1000 1060 15.48 0 0 0 0
16.66 3360 8.44 5.1 2.3 16.97 3240 12.8 1000 1050 16.39 0 0 0 0
17.57 3000 7.72 4.3 2.3 17.91 2880 13.5 1000 1040 17.26 0 0 0 0
18.57 2600 6.86 3.9 0.8 18.87 2560 13.5 1000 1030 18.26 0 0 0 0
19.49 2480 6.33 3.5 0 19.78 2440 13.5 1000 1020 19.18 0 0 0 0
Saturday 25 May 2013 19:37:24:32264 VCDS Version: Release 11.11.3 Data version: 20120401
1.08 2400 8.31 5.1 34.5 0.32 2440 17.3 1000 1020 0.72 0 0 0 0
1.98 2520 48.22 96.1 22.5 1.38 2400 17.3 1000 1020 1.68 0 0 0 0
2.9 2840 86.81 100 15.8 2.32 2600 100.8 2320 1240 2.59 0 0 0 0
3.79 3400 156.47 100 4.5 3.2 3000 163.9 2360 1960 3.49 0 0 0 0
4.81 4120 171.75 100 6 4.1 3600 191.7 2470 2540 4.47 0 0 0 0
5.71 4760 187.64 100 7.5 5.11 4360 191.7 2540 2540 5.4 3 0 0 3
6.61 5240 198.03 100 9 6.02 4920 191.7 2530 2380 6.34 5.3 3 3 2.3
7.52 5720 205.11 100 8.3 6.91 5440 191.7 2510 2250 7.21 5.3 3 3 2.3
8.44 6120 207.08 100 9 7.82 5880 184.2 2490 2200 8.12 4.5 2.3 6 2.3
9.35 6440 204.64 100 12 8.72 6240 175.2 2400 2120 9.02 4.5 2.3 6 4.5
10.23 6720 204.89 99.6 12 9.63 6560 160.9 2260 2140 9.95 7.5 1.5 5.3 4.5
Saturday 25 May 2013 19:40:13:32264 VCDS Version: Release 11.11.3 Data version: 20120401
0.7 2680 55.22 95.3 24 0.01 2520 29.3 1000 1010 0.35 0 0 0 0
1.66 3040 121.03 100 5.3 1.06 2800 113.5 2330 1390 1.37 0 3 0 0
2.59 3680 165.31 100 3 1.96 3240 191.7 2410 2480 2.26 0 3 0 0
3.47 4320 178.06 100 6.8 2.86 3920 191.7 2550 2540 3.17 0 2.3 3 0
4.37 4880 189.22 99.6 7.5 3.77 4520 191.7 2550 2500 4.08 3 2.3 3 3
5.28 5400 201.56 100 10.5 4.7 5080 191.7 2530 2330 4.98 6 1.5 2.3 3
6.18 5840 203.78 100 6.8 5.6 5560 185.7 2500 2230 5.88 6 3.8 5.3 6
7.2 6200 207.42 99.6 6 6.49 5960 178.2 2480 2180 6.9 5.3 3.8 5.3 6
8.1 6560 207.08 98 12 7.49 6320 170.7 2400 2190 7.8 5.3 3 4.5 8.3
9.01 6840 206.28 98.4 10.5 8.4 6640 149.6 2210 2110 8.72 4.5 3 4.5 8.3
