YES!!! I have managed to get my cable (which I got from original link from CarOBDII Factory) to work!!
I Followed Rcopus' virtual machine setup instructions and all is good. When conected to my car the test came back with
K1, K2 & CAN as OK and was able to do an autoscan for fault codes of my current car, Audi 8P A3 so am really happy. Many thanks again rcopus for the instructions, you're a star!!
ac2013, Kugaman - sorry to hear you guys are having issues. I would really recommend trying the virtual machine method again if you get time as that seems to work and provides you with a safe environment to work in like rcopus mentioned.
However having explored the contents of the cd that came with cable there is a 'readme.txt' file which tells you the pre-requisites before attempting to install the software and as long as this is adhered to the install should work in a non virtual environment too. I might try another installation, not in a virtual environment to test. But the pre-requisites before even installing the software is:
1) Ensure that the Laptop does not have access to the internet at all times
2) Change system date of Laptop to 1/10/2013 before running set up file
3) Then after software has installed and you connect USB for first time you may need to manually point to the VCDS folder so that the drivers can be installed.
Did you guys do the above before installing the software??
