cmcc
Cheers,
cmcc.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Hi Andy,I can use that cable.£10 awaiting instruction mate.
Cheers,
cmcc.
I had to change the date on the main operating system.
Use the guides on the german site i posted above rather than the one in the faq section and be very careful with your german - there are lots of options in central electronics!
Cheers Dean -
It wouldnt physically let me do the necessary for changing the interior lights to red....not sure why.
Also, the chirp lock/unlock was all done and activated.....just doesn't seem to work!
Might try again at the weekend!
OH - Also, how did you change the times it washes the headlights?Im sick of mine washing so often - makes a bloody mess of the sides of the car!!!!
Andy
Kugaman I had the same problem with the chirp.. Then I realised you need to go into the car menu on the main display then setup and switch it on!
Ok,
its been a marathon.....but Ive kinda got a little bit done.
I installed the virtual machine on my macbook and eventually got the rosstech software to work....took some hassle but I got there in the end.
Only issue I can't help s that it continually keeps changing the date back to todays date!
I managed to enable staging and also adjust the mpg to be more accurate. Ive also got the fog on turn lights to come on.
However, I cannot get the red lighting to work at all, cannot get the locking chirp to work and cannot get the fan speed in auto to work....so, some success....but still frustrating...
Andy
Has anyone with a wk49+ car confirmed that the mirror drop is now working correctly?
Np, first come first served.
You'll need to enable your pm box as I cant pm you details.
*edit
PM me cmmc when your PM box is sorted![]()
I need he security code for 5F information electronics
