So I can do this with a car jack out the back of my house and it's unlikely I'll **** it up? I dropped the engine in my zx6r to save money when getting work done on that and got that back together alright, just so you know my experience....
Yes no problem. Jack it up take of wheel and panel at end of box
Remove the black cap with a screwdriver ( you'll need to replace this ) then you see the end of the shaft
stick your finger in the hole and pull the shaft as far as it will come and there is a circlip type thing round it get that of ( I used circlip pliers but you'll manage with a couple of screwdrivers) put the shim over the shaft put the clip back on and the new cover job done!
Hi people , I fitted the pcv delete kit today (revo) but engine was choking n cutting out , I've noticed something different with my car compared to other Leon's , the induction kit should have a hose coming off at the 1st bend on left hand side , mines doesn't have it .. Had to refit pcv n car worked fine again !!
my engine bay
if you look at blue hose , I don't have that for some reason . Guessing that's why it's not working engine bay in need of refurbishment !! Will be done soon as I've just bought car few weeks ago .
I have just got off the phone to cr turbo engineering about organising my hybrid think I am going to go for the stage 3 hybrid
