If yours are 286 on the rear then yes they will fit otherwise they wont without new caliper brackets. I have 255mm discs on the rear of my FR
great ! thanks for your help ! cheers to you
Hi, After cleaning up sticky rear pads I'm going to fit new pads (due to wear and overheating damaging the material) to the rear of my FR Tdi, I noticed that the replacement pads come with a fitting kit? that are a couple of stainless steel plates that fit between the pads and the carriers, none fitted at the moment, should they be there as standard? Cheers.
Do you mean anti-squeal shims? Not all brake pad kits come with them anymore - opting in most cases for a built in anti sqeal "pad" that's like an adhesive/rubbery type pad that contacts the piston instead. I personally prefer the shims
