Good job on the change of brakes. Not too hard is it?
B7 is lovely. Or you could get a Passat Estate and get it done up by Jamie Kilner hehehe. His is mental already
Nope not too difficult. Rears are harder than fronts, access to the 14mm spline bolts is bad and also you'll need a right hand thread piston tool to make it easy to push the rear Pistons back in!
Is his still derv? Thinking of 2.0tfsi maybe :)
Of course. Jamie without a ppd170 is like a fish without gills.
I would say they were a solid mid range tyre to be fair. Grip isn't as poor as a set of ling-long's, or Wanli's or similar quality ditch finders, but at the same time they're not in the same league as performance tyres, like Eagle F1's, Michelin PSS's etc.
Set up a streaming device to my headunit so I can stream spotify to my car, no more aux in cable wrapping around the handbrake.
The different between the quality of the music is amazing.
Okay so finally got to the bottom of my misfire.
Did a resistance test on all my injectors 2-4 were at 2.5 ohms and cylinder 1 wasn't even giving a reading. So replaced it with a new injector, and the valves were caked in carbon so have it a clean up with some forte cleaner. Hopefully should run a bit better now :)
I have pictures but don't know how to put them up?
