What did you and your MK2 do today?
Jarre
5,365
11
Stockton-On-Tees
Good job on the change of brakes. Not too hard is it?
B7 is lovely. Or you could get a Passat Estate and get it done up by Jamie Kilner hehehe. His is mental already
Nope not too difficult. Rears are harder than fronts, access to the 14mm spline bolts is bad and also you'll need a right hand thread piston tool to make it easy to push the rear Pistons back in!
Is his still derv? Thinking of 2.0tfsi maybe :)
shnazzle
Glass-Half-Full Member
Sep 9, 2011
3,480
Northumberland
Of course. Jamie without a ppd170 is like a fish without gills.
Dan FR
Meth addict. Stage 2+ Yo!
Nov 14, 2013
1,794
8
Caerdydd
I would say they were a solid mid range tyre to be fair. Grip isn't as poor as a set of ling-long's, or Wanli's or similar quality ditch finders, but at the same time they're not in the same league as performance tyres, like Eagle F1's, Michelin PSS's etc.
aran
31
Set up a streaming device to my headunit so I can stream spotify to my car, no more aux in cable wrapping around the handbrake.
The different between the quality of the music is amazing.
Joshkcupra
Local Retard
Aug 21, 2012
899
Gravesend, Kent
Okay so finally got to the bottom of my misfire.
Did a resistance test on all my injectors 2-4 were at 2.5 ohms and cylinder 1 wasn't even giving a reading. So replaced it with a new injector, and the valves were caked in carbon so have it a clean up with some forte cleaner. Hopefully should run a bit better now :)
I have pictures but don't know how to put them up?
